Old 06-14-2010, 06:50 PM
Scotty1500 Scotty1500 is offline
Vehicle: 2000 dodge ram 1500
Color: red
Scotty1500 is on a distinguished road
Default spray in bed liner
hey, i dont like my plastic bed liner, i wanta do a spray in bed liner and do it my self, how many gallons will i need to do a 6ft bed?
Old 06-14-2010, 10:06 PM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
I would seriously recommend biting the bullet and having it sprayed professionally. The quality is all about surface prep and you'll get some sort of warranty (most likely lifetime if you go with Line-X, Rhino or Ultimate X-treme). I'd guess you'll spend at least $150-200 (minus elbow grease and frustration!) to DIY and for about $275-$350 (depending upon where you go) will get you the real deal. In the end it's your choice but chances are you'll be disappointed if you use your truck bed for any kind of work IMHO.
Old 06-14-2010, 10:33 PM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Vehicle: 2005 Dodge Ram 1500
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
Ya i have to agree! i think it would be more cost effective to have it professionally done! i know the do it yourself stuff can get pretty pricey when it comes to getting alot, especially for your own box! the quality probably won't be as good! the pros are set up right to do it so it will be alot more cost effective, and won't be so labor intensive!!
If your still set on doing it yourself your best bet is to head to your local parts store and take a look most of them should state how much is need for certain areas!! then go from there
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
Old 06-16-2010, 05:37 PM
Grumpy Grumpy is offline
Rep:13
Grumpy is on a distinguished road
Quality is not only about surface prep, but about the product itself. There's quality and junk out there just like most other things.
Old 06-16-2010, 06:24 PM
Rep:2657
I have the Line-X spray in, for me its perfect, as all i have in the bed is 2 very large tool boxes, they are bolted through the bed & will not be coming out as long as i own it.
You can get the spray in liner & you will be happy with it
OR
you can get what i would have purchased if i actually used the bed, it will take a beating, most oils & most acids won't hurt it, you can wash it out, you can remove it, yet its padded & comfortable to sit on, & nothing will slide around on it
http://www.bed-rug.com/ & you don't have to sand the paint off the bed to apply it
Old 06-16-2010, 09:06 PM
Rep:13
Bedrug is a good product for what it is. It's good for light to moderate duty. Most things will wash out except the knap can still stain. Leaves, twigs, and that sort of junk does not wash out. With heavy use, the knap will tear. It's best to use a tonneau cover with a Bedrug or the Bedrug will tend to sag after a while.
