United Radio
Old 06-14-2010, 09:09 PM
msipps msipps is offline
msipps is on a distinguished road
Default 09 ram lift and tire question
will 37s rub with a 6inch lift on my 09 ram 4x4
Old 06-15-2010, 12:03 AM
Rep:1625
You might see some fender rub, but I'm not 100% sure.
Old 06-15-2010, 02:30 PM
djinn4 djinn4 is offline
Vehicle: 2010 dodge ram 1500
Trim Level: SLT Big Horn
Color: deep water blue
Rep:13
djinn4 is on a distinguished road
i was told that 37's wouldnt clear on the 09-10 rams with only 6" of lift. i hope someone can tell me for sure otherwise. i am wanting to put a 6" lift with 37's on my 2010 1500.
Old 06-15-2010, 06:50 PM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Vehicle: 2005 Dodge Ram 1500
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
They may not clear fully, throw a level kit up front for a little more lift, or a body lift to get the more clearance!
If you do the 6" with 37's it will also come down to the wheels you use and the tires, the rubbing would probably only happen at full lock too
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
Old 06-18-2010, 09:45 AM
curt4816's Avatar
curt4816 curt4816 is offline
Vehicle: '11 Dodge Ram Crew
Trim Level: Laramie 4X4
Rep:178
curt4816 has a spectacular aura aboutcurt4816 has a spectacular aura about
37's would only require an inch more clearance than 35's. as long as the tire width stayed the same it would probably work fine. good luck, post pics when your done. very interested in the result
Mods: H&S Mini Maxx w/ egr and dpf deletes
Old 06-19-2010, 03:26 PM
BMD0947's Avatar
BMD0947 BMD0947 is offline
Vehicle: 09 Ram Quad 4x4 4.7L
BMD0947 is on a distinguished road
AutoTruckToys.com
Mopar Performance Dodge Ram Lift Kits 09-10 1500 4WD
Give your Dodge Ram a boost in the height department with a Mopar branded lift kit. Designed to clear up to 37" tires while maintaining factory turning radius. Kits are compatible with all vehicle systems including electronic stability control. Each kit is manufactured to give your Dodge Ram a 4" life over base model Ram's. Since the TRX4 models already have a 1" lift over base model trucks, the supplied kit for that application provides 3" of lift while the application for base models incorporates a 4" lift.
Hope this helps!
"If you chase Perfection, you often catch Excellence!!"
Old 06-25-2010, 06:23 AM
DMG698's Avatar
DMG698 DMG698 is offline
Vehicle: 2012 Dodge Ram 3500
Rep:17
DMG698 is on a distinguished road
37s wont rub if you have a 6" lift on. i have the mopar 4" and i fit BF Goodrich 37x12.5R20 there is a slight rub for me in full steering lock out. im going try throwing a 1/4" spacer in to completely get rid of the rubbing
Old 11-22-2011, 10:57 PM
Fireman32118 Fireman32118 is offline
Vehicle: 2009 dodge ram 1500 4x4 trx4
Trim Level: Crew cab trx 4x4
Color: Blue
Fireman32118 is on a distinguished road
Default 2009 dodge ram 1500 trx4
Hello i have a 2009 dodge ram 1500 4x4 crew cab trx ive been looking at lift kits and not getting anywhere i only found one lift and its a 6 inch lift by bds and its over 3000 dollars is there any more cheaper opptions Please help my fellow ram friends
Old 11-25-2011, 05:36 AM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
When I had my 6" BDS lift installed with 37x12.50x20 with 20x10 -18 offset and 4.7 back spacing mine did not rub at all.
Do not do any spacers on top of your lift your asking for trouble. get some bilstein 5100's if you want to lift the front more.
I can get you a BDS kit a lot cheaper then 3k.
