Old 06-14-2010, 09:23 PM
dodgeramdriver's Avatar
dodgeramdriver dodgeramdriver is offline
Vehicle: 2005 Dodge Ram 1500 Quad Cab
Trim Level: SLT 4X2
Color: Dark Blue
Rep:13
dodgeramdriver is on a distinguished road
Default It's summertime....let's talk temp gauges!!!!
I'm interested to see where everyones temp gauge usually sits at on a hot day. It hit 100 degrees today here in Augusta with a even higher heat index and here is where my temp gauge went up to. Is this regular temperature for these trucks in the sumertime or is mines a little hot?
Old 06-14-2010, 09:25 PM
Rep:1885
Looks a bit hot to me. Have you backflushed your cooling system lately?
Old 06-14-2010, 09:27 PM
doz doz is offline
Vehicle: 2014 Dodge Ram Crew Cab 4x4
Rep:76
doz will become famous soon enough
Car runs at 204* all day here in Vegas.
DS Trinity w/ custom tune, S&B Intake, ARH LT Headers, Magnaflow Cat-back, 87mm PTB, BT Catch Can, 180* T-Stat, v6 E-Fan, 5000k RS HID, XD Misfits w/ 35"x12.5"x18", Rancho QL level, 5% tint w/ 35% full windshield, Hifonics Brutus 1100.1 w/ Sundown SA12 in ported FoxBox
Old 06-14-2010, 09:31 PM
Rep:1885
Given the climate there and the stock stat being 195F, that's not bad at all.
Old 06-14-2010, 09:47 PM
Trim Level: SLT 4X2
Color: Dark Blue
Rep:13
No, I haven't back flushed it. I have only had this truck for about 4 months. Is it recommended to change it every so often? I have noticed that my coolant level has been going down by about a quarter of a gallon every month.
Old 06-14-2010, 09:50 PM
doz doz is offline
Rep:76
1/4 gallon? Do you see any dripping out? If not, have you checked your oil lately to see if you have coolant in your oil?
Blaze 4X4 Ever Blaze 4X4 Ever is offline
Color: White over Tan
Rep:36
Blaze 4X4 Ever is on a distinguished road
Mine runs 203-204. It gets hot and humid in Augusta. I used to live in Aiken and also North Augusta. Augusta...home of the Masters.
Old 06-14-2010, 09:51 PM
Rep:1885
You should definately have it flushed if you don't have proof that it was done within the last year or so. What you've described so far is symptomatic of a radiator that's starting to get clogged up but it could be something as simple as the radiator cap going bad.
Old 06-14-2010, 10:01 PM
Trim Level: SLT 4X2
Color: Dark Blue
Rep:13
Yes it is some signs of coolant leaking on one of the lower hoses going to the radiator. Can't find a source of the leak though.
So could a clogged up radiator or bad cap cause a small leak? I may flush it this weekend if that is the problem.
Old 06-14-2010, 10:09 PM
Rep:1885
A bad cap could allow coolant to escape. Old or coolant types being mixed can definately cause the radiator to clog. You can flush it yourself but it would be better to have it backflushed.
engine, gauge, summer, temp, temperature
