Old 06-16-2010, 02:12 PM
caper10's Avatar
caper10 caper10 is offline
Vehicle: 2010 Ram1500 Quad Cab
Color: Mango Tango
caper10 is on a distinguished road
Default Advice on Gear Ratio
I'm in the process of shopping for a 2010 Sport quad cab. I'm still a little up in the air on grar ratios, 355 or 392? The trusk will be mostly highway drive and i'll be buying a travel trailer in the next year or so. What is the difference in gas mileage, and will it make much of a difference in towing 355 VS 392.
Extang Solid , EGR Visors, Vision Warrior 17" winters with studded snows, Iron Cross HD , HBS 2.5"
Old 06-16-2010, 02:26 PM
jj ram's Avatar
jj ram jj ram is offline
Vehicle: 2014 Dodge Ram 4x4
Trim Level: Outdoorsman
Color: Maximum Steel Metallic
Rep:16
jj ram is on a distinguished road
Hi,
I was in the same boat as you, mostly highway and towing a travel trailer a couple times a summer. I went with the 3:55, mostly because that's what they had on the lot, but in the end I don't think you notice the difference that much. Since you are probably not towing all that much or racing your truck, I think you would benefit from the slighlt better gas mileage of the 3:55 on the highway.
Perhaps somebody with the 3:92 can tell you better, but I had them on my 04 Ram and I didn't notice it was that much of an improvement. mind you I had the 4.7L which sucked for towing....
"They will not force us, they will stop degrading use, they will not control us, we will be victorious" - Muse
Old 06-16-2010, 02:33 PM
Rep:1845
If it's heavier than a pop up camper, I'd go 3.92, especially if you're going to be in the mountains any.
Old 06-16-2010, 10:10 PM
dafoot dafoot is offline
Vehicle: 2011 Dodge Ram, 1500, Hemi
Rep:16
dafoot is on a distinguished road
I have 355s. My answer is....not sure. I pull a 5 to 6 thousand pound boat. Seams to pull ok. What I don't like is the tourqe converter going out of lock up on certain hills. (in 4th gear). I came from the Tundra with 410s. That truck never left lock up in 4th gear. Of course the rpms were higher in the Tundra. If I new the Ram would stay in lock up..I would go with the lower gears.
DAFOOT
Old 06-16-2010, 10:46 PM
Raptor1000R's Avatar
Raptor1000R Raptor1000R is offline
Vehicle: 2010 Ram 1500 4x4 Sport Crew
Trim Level: Sport, buckets, RER
Color: bright white
Raptor1000R is on a distinguished road
I suggest 392's. Your mileage won't suffer more than 1mpg on an "all highway" trip, and doubt you'd notice it otherwise. I went from 355's to 410's in an f150 and the highway mpg went down 1mpg, but the in town went up 1mpg. I saw it as a wash, but it pulled trailers awesome. It would basically not use OD with the 355's, but the 410's ran the same rpm at 75mph as the 355's in did w/o OD. I think 392's would be perfect. I sure wish my `10 had 392's, though I don't pull most of the time. The beef will prob. come down to you having to order 392's if you chose that route. I haven't seen any 09+ with 392's. Just my $.02
2010,15004x4,Hemi,Sport,White,Crew,CAI,Predator,Li ne-X,Truxedo Lo Pro,2"level kit,PE Powergate
Old 06-16-2010, 10:52 PM
Rep:1845
I'm not surprised to hear this with that kind of load on the back, especially when you consider the 545RFE is a double overdrive transmission.
Old 06-17-2010, 01:14 AM
Yotaman96 Yotaman96 is offline
Yotaman96 is on a distinguished road
I don't like my 3.55s at all. The truck constantly downshifts even on the slightest hills. It struggles towing things that my Titan never had an issue pulling. I have a friend that has the 3.92s and he always gets better mpg than me. Definately go for the 3.92s.
2010 Ram 1500 Crew Cab 4x4 Sport
Old 06-17-2010, 01:34 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
3.92's all the way! Even if you don't plan to pull a trailer.
Locally, I have been able to run caparison tests between a few 09/10 Rams. 3 have 3.92's, 5 have 3.55's 2 have 3.21's. The ones with 3.92's consistently get the best gas mileage both city and highway. The 3.55's ad 3.21's are about the same. The 3.21's are IMO a complete waste of time, especially if you pull a trailer. The 3.55's are fine, but don't seem get the mileage of the 3.92's.
These are absolutely NOT the results I expected.
Most recent trip - 515kms (~320miles) - 4 2010 Ram 1500's with 5.7 All QC but 3.21 - It's a RC LB.....
About 400kms - highway, remainder - urban
Highway cruising speed - 110kmh (~70mph)
Wind - 5-10 mph, crosswind Temp - 21degC (~70degF)
1 - 3.92 - 23 mpg (mine)
2 - 3.55 - 21.5 mpg
3 - 3.55 - 21 mpg
4 - 3.21 - 21 mpg
AND - I was the only one of the bunch that 'Hot Rodded' a bit during the trip. (1 Ford, 2 Chev......toast!)
brad
Interested in one of my mods?
Old 06-17-2010, 01:55 AM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Vehicle: 2005 Dodge Ram 1500
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
I would go for the 3.92!! i have heard many complain the if you tow with the 3.55 you will really notice it on an type of incline!!! Plus when it comes down to the mileage i don't think your going to notice enough compared to the towing....plus your driving a truck, 1 mpg better really won't be that much better, its still gonna take fuel!
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
Old 06-17-2010, 08:50 AM
Rep:16
Are you saying 4th and 5th are overdrive gears?
DAFOOT
