A/C blows hot. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 06-16-2010, 07:41 PM
gdeezy's Avatar
gdeezy gdeezy is offline
Vehicle: '97 Ram
Trim Level: Blackin' Out
Rep:76
gdeezy will become famous soon enough
Send a message via AIM to gdeezy
Default A/C blows hot.
Well, the title says it all, and I've noticed the A/C clutch isn't engaging, the wheel isn't spinning inside of the belt. Now, it might not be blowing HOT persay, but it's always hot as hell here, so I can't tell. Any ideas? Thanks
Old 06-16-2010, 09:13 PM
tmerritt530's Avatar
tmerritt530 tmerritt530 is offline
Vehicle: 2004 Ram 1500 4.7L "H/O"
Color: Graphite Metallic
Rep:98
tmerritt530 will become famous soon enough
When the refrigerant charge is too low the A/C will not engage. OR the relay for it is fried. I would start with these two things. Best of luck hope you get it going cuz driving without air sucks!
2004 SLT RCSB 4.7L | 3.92 | OEM Off-Road wheels | Cooper Discoverer ATP 285/70R17 | Gibson short tube headers | MBRP cat-back | H/O cams | H/O cyl heads | Transgo reprogramming kit
Old 06-16-2010, 09:27 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PXR Black
Rep:2477
Smile
Like the previous post stated, if the charge is low the clutch will not engage and all you will have is hot air blowing out of the vents. I would check the fuse for the A/C compressor first and also see if you can manually turn the inner part (without the engine running of course). If the fuse is good and the compressor has not seized up you need to put some gauges on and see what your pressures are. If its just a bit low you can add some refrigerant slowly to the low side (Large hose) until the compressor starts to cycle on and off. Typical pressures when everything is working properly is ~30psi on the low side and ~150 psi on the high side (when the compressor is turning). Hope you can sort this out. If you don't feel comfortable doing this yourself you should take it to an A/C specialist for diagnostics and service.
sales@revelperformance.com
Old 06-16-2010, 09:53 PM
Resident Technician
Rep:1915
Don't forget the pressure switches!
