Old 06-16-2010, 10:10 PM
BigHornInferno BigHornInferno is offline
Vehicle: 2008 Dodge Ram
Trim Level: 1500 SLT Big Horn
Color: Red Inferno Crystal Pearl
BigHornInferno is on a distinguished road
Default HID Install PLease Tips
i got my lights in the mail and i got the hi/lo headlight kit with the seperate relay for the hi beams and the relay harness. Now any tips on what else i will need i bought capacitors and i guess they just get wired in line with the hi n the low wire. pleaase if u have any tips let me know i wanna do it once n have everything i need. its going into an 08 ram 1500 THankss please help me out
Old 06-17-2010, 12:27 AM
bumpp, anyone help me out if they ever did their own dodge ram same year?
Old 06-17-2010, 01:48 AM
MS520's Avatar
MS520 MS520 is offline
Vehicle: 2004 Dodge Ram
Trim Level: Hemi
Rep:109
From the sounds of things, you have everything that you need.
Before I do any HID install, especially hi/lo kits I lay everything out and figure out what goes where so I do it right the first time and it doesn't take long.
You'll be fine.
GL!
Mike
'04 Ram
"Yea its got a hemi!"
Old 06-17-2010, 07:23 PM
RockStarRam
where did you get the capacitors?
Old 06-17-2010, 07:44 PM
MS520's Avatar
Trim Level: Hemi
Rep:109
This is what I used and it works great! I installed my HIDs today and they are amazing!!!!
I got mine from http://www.ddmtuning.com
It is called the Error Code-5 eliminator. You probably have to call to get one because they are running tests on Dodge's next week. I called like 10 minutes ago so that is how I know this.
Mike
'04 Ram
Old 06-18-2010, 12:56 AM
ya my lights are from ddmtuning.com and i got the relay harness that they have there and i got the capacitors from radio shack 2200uf and 35w
Old 06-18-2010, 12:57 AM
did you also use the relay harness for ur truck or just the other part
Old 06-18-2010, 01:55 AM
MS520's Avatar
Trim Level: Hemi
Rep:109
I used the error eliminator and I also got a hi/lo kit but I am experiencing a flickering issue. Everytime I unlock the truck or even open the door the HIDs flicker quick. Then the hi beam doesn't turn on.
I'm thinking that I actually may need another relay harness besides everything that I already have.
Mike
'04 Ram
Old 06-18-2010, 11:36 PM
its such a pain in the ass man i dont know why it would b so hard
Old 06-19-2010, 12:58 AM
MS520's Avatar
Trim Level: Hemi
Rep:109
So I believe that I figured it out.
With this kit, you need the hi/lo relay, the error code eliminator, a relay harness to eliminate the flicker and so the hi's will work, and also the HID kit. Oh boy, I already know that this is going to be an on going process but when the low's and fogs are lite, omg it is pure sex.
Mike
'04 Ram
