MOPAR DECALS
Old 06-17-2010, 12:29 AM
Ramspeed Ramspeed is offline
Vehicle: 1997 Dodge Ram 1500
Color: Black/Grey int.
Ramspeed is on a distinguished road
Send a message via Yahoo to Ramspeed
Default Engine runs backwards!
New here.. I have a 97 1500. Engine started to rev (3500rpm)No power, just sat there. thought my trans was slipping, but once I let off gas, she shifts fine. Check eng lite came on. changed PCV and cleaned injectors. Ran fine 2 days. Then on freeway she reved again, no power... took back to mechanic. Check eng lite came on again, said #5 misfire. He said cyl #1, 3, 5 and 7 have a problem. Now the truck will not start. When we try to crank, the engine ran bacwards, unscrewing the fan into the shroud. WTF! I was told the engine needs a total rebuild at the tune of $3200 bucks! I am totally mystified... Anyone have the same problem?? The truck has 216,000 miles. When this all started... I was trying to pass a rice burner on a grade, heard a "POP" and thats all she wrote.....HELP!
Thank you for the Ram forums...
Old 06-17-2010, 12:41 AM
Rep:4253
Well first, welcome to the forum since I see this is your first post! Unfortunately, I don't really have any advice for you but hang in there, someone should be along shortly who can help, but good luck with that and be sure to keep us posted! In the meantime, be sure to introduce yourself in the Newbie Checkin and get your official Ram Z welcome!
Old 06-17-2010, 09:14 AM
Rep:1625
Welcome to the forum!
Old 06-17-2010, 09:32 AM
I'd look at your timing chain.
Old 06-17-2010, 09:34 AM
Resident Technician
Rep:1915
Excuse me while I laugh myself sick over the engine running backward notion! I don't buy that for one minute unless this so-called mechanic can explain to me how the engine can run backward. You need to find a qualified mechanic that has a clue.
Old 06-17-2010, 09:40 AM
I wonder if the gear at the bottom of the distributor disintegrated....
Old 06-17-2010, 10:05 AM
Resident Technician
Rep:1915
Lots of this could cause the no start amd misfires but in order for it to run backward, the starter would have to crank the engine backwards.
Old 06-17-2010, 10:24 AM
KC Chally Snob's Avatar
KC Chally Snob KC Chally Snob is offline
Location: we live in Blue Springs Mo. its just out side Kansas City Mo.
Rep:18
KC Chally Snob is on a distinguished road
Welcome to the forum! I'm with Randy on this one. To my knowledge it's impossible to run a gas engine backward.
Old 06-17-2010, 03:38 PM
Thanks for the response... I was going to pull the distributor and look at the timing chain, but I swear.. I saw this thing turn backwards for a few seconds...It looks as if the fan is held in place by a large nut(not me!) perhaps left hand thread, and it spun off!
Old 06-17-2010, 03:44 PM
Resident Technician
Rep:1915
Did your "mechanic" say what the problem with the left bank was?
