overhead console works sometimes! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 06-17-2010, 06:12 PM
Stage1's Avatar
Stage1 Stage1 is offline
Vehicle: 2004 Dodge Ram 4 door 4x4 HEMI
Stage1 is on a distinguished road
Default overhead console works sometimes!
I have an 04 Ram 1500, and the overhead console works sometimes! Had the the hole thing replaced, and still comes on one time and the next time it's off.
Does anyone know where the power and ground wires are(like under the dash or under the hood)?
Thanks for any help,
Robert
If it can't get there on it's own, then leave it at home!
1969 Buick GS400 Convertible, v8Buick.com
Old 06-26-2010, 11:45 AM
Stage1's Avatar
Anyone?
Old 06-26-2010, 11:50 AM
Resident Technician
Rep:1915
Old 06-26-2010, 11:53 AM
Resident Technician
Rep:1915
The S230 splice connects the display to the rest of the grounds in the cab. If you have a ground problem, it will be between the display and that splice since everything else seems to be working. Check the connector itself in the overhead display for looseness or spread pins and check the fuses for the same thing. If you can catch it doing it with the display removed, check the RD and PK/DG wires for power. If all the power and grounds check out, you probably have a PCI bus or trip computer problem.
Old 06-26-2010, 11:59 AM
Stage1's Avatar
Thank you! Going to check. I'll let you know.
Old 06-26-2010, 12:32 PM
Stage1's Avatar
Ok, just looked all the pins look good and fuses are ok. Did not find S230 splice. I need to know where it is. (Just turned the key and it was on, and the next time Less than 1 min. apart, I turned the key it was off! )
Thanks!!
Old 06-26-2010, 01:12 PM
Resident Technician
Rep:1915
I can't seem to locate it but if you have a DVOM you can check continunity on the ground circuit.
Old 06-26-2010, 01:30 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Thanks!!
S230 is behind the left side of the glove box, right at the main wiring harness...at the firewall. It's the one they started with, and built the truck around.
brad
Interested in one of my mods?
Old 06-26-2010, 01:56 PM
brad12kx's Avatar
Rep:2581
Here's a location drawing -
brad
Old 06-27-2010, 09:13 AM
Resident Technician
Rep:1915
I'd tie in another ground before I went to the aggravation of digging into that splice.
