Old 06-17-2010, 07:16 PM
ScatPak07's Avatar
Rep:970
Default How do you install 180 degree Thermostat
Hey Everyone!!
I know it may be a stupid question but I do not know how to install the 180 degree thermostat. I know the thermostat is at the rad outlet (if I am not mistaken haha). I just wanted to know how to do it. I have no instructions or anything. I can get y buddy to put it in but I would like to do it myself.
I got the Jet 180 deg just yesterday. I hope it makes a little difference to the way she drives.
Any help would be appreciated!! Thanks in advance!!
Old 06-17-2010, 07:49 PM
Rep:1882
WARNING: Do not loosen the radiator draincock with the cooling system hot and pressurized. Serious burns from the coolant can occur.
  1. Disconnect the negative battery cable.
  2. Drain the cooling system
  3. Remove the radiator hose clamp (3) and radiator hose (4) at the thermostat housing (2).
  4. Remove the thermostat housing mounting bolts (1), thermostat housing (2) and thermostat .
  5. 1 - BOLT 2 - THERMOSTAT HOUSING 3 - CLAMP 4 - RADIATOR HOSE
Old 06-17-2010, 10:24 PM
hpc3 hpc3 is offline
Vehicle: 2010 Ram 1500 Laramie Crew 4x4
Color: Inferno on Slate
Rep:44
hpc3 is on a distinguished road
Send a message via AIM to hpc3
Measurable gains? Know this is popular with tunes.
2010 Ram Laramie Crew 4x4, Inferno(mono) on Slate, All options, including BigSloshiTank
Old 06-17-2010, 10:25 PM
Blaze 4X4 Ever Blaze 4X4 Ever is offline
Color: White over Tan
Rep:36
Blaze 4X4 Ever is on a distinguished road
Remerson, great diagram and answer.
Old 06-18-2010, 07:37 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
LOL Randy had a much better answer than the one I was gonna give....
I was gonna say to wait until the truck was cool, crack the rad cap, then follow the outlet hose to the t-stat housing. It's then just a matter of unbolting the housing cover, popping out the old t-stat and inserting the new one. Then reversing the process, making sure to use a new gasket when reinstalling the housing cover..
just my opinion (never changed the t-stat on a Ram, but have done so on several other vehicles)
Exco
Bill
Old 06-18-2010, 07:22 PM
ScatPak07's Avatar
Rep:970
Damn thanks Remerson! I will print this off when I go to do it! I am hoping to get it in tomorrow. It should take an hour or so correct? Tried to give you rep but I cant haha
Thanks everyone for the help!! I appreciate it!!
Old 06-18-2010, 07:24 PM
Rep:1882
Yeah, an hour is a fair guesstimate for someone that hasn't done one before. BTW, you don't have to drain the cooling system completely, just let it drain until you get about a gallon oout of the radiator and you should be fine.
Old 06-18-2010, 08:43 PM
Rep:1625
I'm looking forward to hearing your review on it Scat
Old 06-18-2010, 08:50 PM
got hemi's Avatar
got hemi got hemi is offline
Vehicle: 2004 Dodge Ram
Color: Platnum Metalic / Silver
Rep:40
got hemi is on a distinguished road
i did my tstat with the jet 180 and it makes allittle noticeable on the low end, tires seem to be chirpping more on fast pull outs. and since i put the tbody spacer and intake on, its like hell on wheels. like remer said its easy to do, follow his guidance.
Mr. Grimm
Mod list here :
http://www.ramforumz.com/album.php?albumid=130
Old 06-18-2010, 08:58 PM
PimpJuice's Avatar
PimpJuice PimpJuice is offline
Vehicle: 2007 Dodge Ram 1500
Color: Blue
Rep:150
PimpJuice has a spectacular aura aboutPimpJuice has a spectacular aura about
This might sound dumb, but does the jet 180 t-stat only fit in a hemi or could i put one in my 4.7?
