Old 06-21-2010, 09:56 AM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 2014 Ram 1500 Quad
Trim Level: Lone Star
Color: Blue Streak Pearl
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
DARN good post Chefred!!!!! Lotsa good info!!! (Saved to fav's)
My 09 is set up with both an electric and a 'clutch' fan,,, Wondering how a person would morph the 2 systems / go to full electric,,,,
I haven't looked, but I doubt the OEM electric has a shroud. Its on full time with the A/C as I understand, but evidently isn't 'enough' to cool the whole engine.
Hmmmm,,,,
Old 06-21-2010, 10:03 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
the 3rd gen's also have a smaller efan for the ac (altho it has a mind of it's own and comes on whenever it feels like it..lol)... I'll have to take a peek of the 4th gen's to see if the fan's are setup any different..
Old 06-21-2010, 10:08 AM
Rep:135
(altho it has a mind of it's own and comes on whenever it feels like it..lol)... ..
(Theme from PSYCHO playing in background!) LMAO!!!
Old 06-22-2010, 08:10 PM
ScatPak07's Avatar
Rep:970
Thanks for all the write up Chefred! Really let everyone know what they all do!
I am going to go with the Taurus myself. I think it will fit better than the Mark 8 and it also runs quicker as well. They both have the same CFM so it does not really make a diff I guess.
Thanks man!
Old 06-22-2010, 10:23 PM
onewheelregulator's Avatar
onewheelregulator onewheelregulator is offline
Trim Level: Sport 4x2
Color: Mineral gray
onewheelregulator is on a distinguished road
So once you have a efan installed do you remove your stock fan and how? Where does the efan mount? Infront or behind the radiator? What do you wire the fan too?
15%tint, Daystar 2" level, Flowmaster 40 w/ deleted resonators, Helo 866 24's
Old 06-22-2010, 11:36 PM
chefred112's Avatar
Rep:656
yes.the fan comes off..by the big nut at the water pump. typically, the efan will mount inside the stock shroud or can be mounted by itself with a mount. (so behind the radiator).. you typically wire it to a fan controller.
Old 06-24-2010, 07:56 PM
wilbrakloose's Avatar
wilbrakloose wilbrakloose is offline
Vehicle: 2004 Dodge Ram
Rep:26
wilbrakloose is on a distinguished road
Originally Posted by HoustonHemi View Post
Some PICS of a Taurus e-fan installed on a RAM would be nice!
here is my Mark VIII, the stock shroud was removed, i made a custom overflow bottle (abs pipe) and relocated the washer bottle, i have 2 controllers one for the low speed and one for the high speed, the high speed is set to came on about 15 degrees higher than the low but it never cames on, the low speed keeps up pretty good
nothing i can think of
Old 06-24-2010, 10:09 PM
Rep:135
THANKS for the pic!!!
The 3rd gen is set up quite a bit different than the 4ths in regards to rad, condenser coils, overflow and WW fluid,,,,
The condenser is 'stacked' in front of the rad, and the overflow/WW is 'in front of/off to the side(s) of the condenser coils,,,
Color: Mineral gray
Did it bolt right up or did you have to fab a way to mount it?
Old 06-24-2010, 11:34 PM
onebadbee's Avatar
onebadbee onebadbee is offline
Vehicle: 2005 dodge ram
Trim Level: rumblebee
Color: yellow
Rep:16
onebadbee is on a distinguished road
i would get the viper fan its what i have and that thing moves a lot of air
12.86 1/4 N/A 1.69 60FT N/A no heads no nitrous no power adders
