Oversize oil filter? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 06-17-2010, 10:58 PM
Flaminchiten Flaminchiten is offline
Vehicle: 2010 Ram 1500
Rep:42
Flaminchiten is on a distinguished road
Default Oversize oil filter?
Is there an oil filter we can get for our trucks that is larger than the factory? My old 2000 SS Camaro could use the truck oil filter that was slightly larger than the standard filter. Anything like this for our trucks?
Old 06-17-2010, 11:15 PM
Blaze 4X4 Ever Blaze 4X4 Ever is offline
Color: White over Tan
Rep:36
Blaze 4X4 Ever is on a distinguished road
I don't know the answer but I would think a parts store could do a cross reference and find a larger filter that would work. Also you can take the recommended filter and match the screw on hole, diameter and gasket with a larger filter and try that. Courious why you want a larger filter. I would not think a larger filter would necessarily clean better just use a higher grade filter. It wouldn't provide much additional oil capacity. Just courious.
Old 06-17-2010, 11:18 PM
Resident Technician
Rep:1915
Use a high quality filter like Wix or purolater and keep it changed according to the manual and there's no reason to bother with a bigger filter.
Old 06-17-2010, 11:25 PM
Rep:42
I agree but I would rather use a larger high quality filter for the same price than a smaller high quality filter.
Old 06-17-2010, 11:27 PM
Resident Technician
Rep:1915
For what reason? If you keep the oil changed at recommended intervals, there's no benefit.
Old 06-17-2010, 11:29 PM
Engine: 2002-2012 226ci (3.7L) Magnum/PowerTech V6 215hp 235lb/ft
Rep:4376
I have to agree with Blaze in wondering, why a bigger filter?
Old 06-17-2010, 11:45 PM
Rep:42
Because more filtering surface with the same flow rate is better than less filtering surface with the same flow rate. Why wouldn't you want more filtering with the same flow rate in your oil filter?
Old 06-20-2010, 01:08 PM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 1492 Santa Maria
Color: Hot pink
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
I can understand both arguments here. I'd darn sure opt for a larger filter if the cost was comparable though! Capacity, cooling,,, nothing to loose, something to gain,,,
FWIW, the OEM filter is 'decent' sized. The OEM filter that went on my 5.3 Silverado was smaller than the one on the wifes 2.5 Honda Accord! The 5.3 filter was about the size of a coffee cup,,,
Now, if I could get a true '1 qt' filter instead of the OEM '1/2 QT' for comparable $$$, why not?
On a sidenote, my EVIC has been calling for oil changes about every 3,500 miles/100 hours. Well, that chit ain't gonna cut it now that I've switched over to MO 1. The new 'mark' is 5,000 miles whether EVIC likes it or not.
But, back to the OT, if there is a larger filter, I'd like to know.
Old 06-20-2010, 01:23 PM
Resident Technician
Rep:1915
This is a valid argument assuming both filters have the same rating in microns (or beta rating, if you go by the latest testing method found here http://filtercouncil.org/techdata/tsbs/89-5R3.pdf ). You talk about using a larger filter for the same price (which I would not expect to trap the smallest contaminants) instead of a smaller filter that is capable of more efficient filtering. Chances are you won't find a larger filter of equal quality at the same price.
Old 06-20-2010, 03:57 PM
Rep:42
I have done some searching and have not found anything.
My camaro's oil filter was tiny and the truck oil filter was the exact same only longer, and the same price so it was a no brainer for me to use the larger filter for the same price.
