Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
ZDOG
Old 06-18-2010, 12:37 AM
farmboy2500's Avatar
farmboy2500 farmboy2500 is offline
Vehicle: 1994 dodge ram
Trim Level: 2500 reg. cab 2wd
Color: red/black
farmboy2500 is on a distinguished road
Default not safe to drive...help me please
my front driver tire bounces like hell.. which causes the whole truck to shake like crazy. when i keep left pressure on the wheel its ok but when i let go or turn right the truck and tire go nuts... up and down bouncing... so i stopped it and when i kick the tire from left to right it moves alot more than it should i feel but neways please let me know what yall think... thanx
Old 06-18-2010, 12:50 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Sounds to me like your truck needs to see a front end doctor....and possibly a tire doctor too!
brad
Interested in one of my mods?
Old 06-18-2010, 12:52 AM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
have you hit anything recently? did any custom work?
Old 06-18-2010, 01:00 AM
Rep:4110
You're getting play in the tire when you kick it? I am by no means a mechanic, and I'm sure someone will come along with a better suggestion, but have you put it on a jack and checked it out, possibly for a bad wheel bearing? Like I said, this is just my suggestion from what I have experienced, but good luck and be sure to keep us posted!
Old 06-18-2010, 06:54 AM
Resident Technician
Rep:1911
You probably have a tire with a broken belt. check the tread and see if any part of it is out round.
Old 06-18-2010, 10:31 AM
Color: red/black
yeah i hit a big ass whole the other day...no custom stuff.....thaught bout the wheel bearing too..... also um yes i do have a big dip in the middle of the tire, bout the size of a softball right in the middle of tread in the tire
Old 06-18-2010, 10:33 AM
Resident Technician
Rep:1911
Bet if you replace that one with your spare, the problem goes away.
Old 06-18-2010, 10:47 AM
Color: red/black
yeah i just went out and looked at it the egg in the tire is huge and the tread is starting to split and show wire
Old 06-18-2010, 10:52 AM
Resident Technician
Rep:1911
Problem diagnosed...now all you need is new rubber and you're set.
Old 06-18-2010, 03:23 PM
Color: red/black
ok i put two new tires on it and its all good... thanx alot guys
