Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2010 Dodge Ram Forum
Old 06-18-2010, 09:38 PM
LARAMIE382's Avatar
LARAMIE382 LARAMIE382 is offline
Vehicle: 2010 DODGE RAM
Trim Level: LARAMIE CREW CAB
Color: BRILLIANT BLACK
Rep:25
LARAMIE382 is on a distinguished road
Send a message via Yahoo to LARAMIE382
Default What gears to go with?
So i have a 2010 ram crew cab hemi 4x4. My truck is recently sitting on 28s 295-25 series tires. I am having difficulty selecting the gear ratio for my truck because i also want to bagg it. so what would you guys recommend going with. thanx for your input
Old 06-18-2010, 10:16 PM
Blaze 4X4 Ever Blaze 4X4 Ever is offline
Color: White over Tan
Rep:36
Blaze 4X4 Ever is on a distinguished road
Sorry but having a little trouble understanding that tire size configuration for that truck. I have the sam truck, I think, and am runningP275/60R20s; which I believe is a 33" tire. I am not sure what the stock rear ratio would be, but I went with a 3.92 and am very pleased with the performance, pulling power and gas mileage.
Old 06-18-2010, 11:20 PM
Rep:3322
K, you're looking at a 34" overall diameter (tire + rim), so check this link out and it's got a good amount of info for RPM, and gear ratios
http://www.iwerearendsonly.com/docs/..._rpm_chart.pdf
now, for a 34" tire I'd look at 3.92s; as well, if you want more get-up-and-go and don't mind sacrificing fuel economy you can more up to 4.10s
Old 06-18-2010, 11:28 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
You didn't say what you currently have but based on your 34" tire I'd go with the 4.10s. It's only an 80 RPM difference at 70 mph when comparing the 3.92 to the 4.10.
Old 06-23-2010, 07:00 PM
LARAMIE382's Avatar
Rep:25
thank you all for the input, yes i do have the 3.92 stock gear ratio at the time, and let me correct this mistake, i currently have 28 inch rims on it havent measured the overall height of tire or width) the tire size is 295-25-r28, im not real good at determinig what gear ratio i need for which i also want to install airbags, not for load but front and back to lower it, not sure if the bagging will make a difference for the gears, but thats my question, determining what gears i should use with the setup i have, all i really know is that when you go big on wheels, lower or lift a vehicle you must re-gear it, or i might just be breaking my head and not need it if i already have the 3.92, but thankx again ramforumz family
Old 06-23-2010, 07:18 PM
Rep:2804
unless you have some crazy type of custom wheels, i believe that you made a mistake
the largest wheel that comes from the dealership, is the 20" wheel, even on the Dodge Chassis CABs 3500, 4500, 5500 models, & the Rams are only 1500 & 2500 models & possibly some 3500
you can get an aftermarket wheel that i have seen that is 28", but, they were 8 lug
bagging, raising, & lowering will add some amount of weight, but, your rear end should be just fine
Old 06-23-2010, 07:33 PM
onewheelregulator's Avatar
onewheelregulator onewheelregulator is offline
Trim Level: Sport 4x2
Color: Mineral gray
onewheelregulator is on a distinguished road
Look at his avatar....those wheels look big enough to be 28's but im wondering how much rub your getting or is it not at stock hieght?
15%tint, Daystar 2" level, Flowmaster 40 w/ deleted resonators, Helo 866 24's
Old 06-23-2010, 10:48 PM
CHVYKLR's Avatar
Rep:252
I remember a short while back when you posted a thread about your new 28s. Based off the above tire size you have a 34" overall diameter wheel/tire setup. If you have 3.92s I don't think you need anymore gear unless you are wanting more get-up and go from light to light.
Going from 3.92s to 4.10s would be a waste of money so you'd want to step up to 4.56s...otherwise you won't even notice the change.
Here is a website to calculate your rpm based off tire size. At the bottom of the page is the tire height calculator. Plug in your info (295/25-28) and you get 33.81".
http://www.ringpinion.com/Calc_RPM.aspx
Next use the calculator above that titled "for specific transmission ratio" to find your rpm based off whatever speed you pick. Your fifth gear is a 0.67. Here is what I found:
1828 rpms at 70 mph with your 3.92s
1912 rpms at 70 mph with 4.10s
2126 rpms at 70 mph with 4.562
If you want the hole shot and can live with 2126 rpms on the hwy then I say go for the 4.56s.
Hope this helps and btw if you do a gear sway let me know and I'll buy your rear axle gear.
