Old 06-18-2010, 11:56 PM
Brent S Brent S is offline
Vehicle: 2003 Hemi Ram Quad cab
Color: The lighter blue
Brent S is on a distinguished road
Default A/C question
Aloha All
I have a 2003 Ram, 5.7 hemi. A/C works fine on highway, but compressor kicks in and out while idling. Refrigerant level checks OK. Any Ideas?...
Thanks
Brent
My other car is a Pro Street 55 Chevy
Old 06-19-2010, 10:56 AM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Pretty sure that's normal. Compressor isn't turning as fast when idling, so the compressor cycles. As long as refrigerant is OK, and you're staying cool, you should be fine.
Old 06-19-2010, 11:02 AM
Rep:1909
Compressor cycling is based on evap temps and line pressures. As long as your a/c still gets cold, what you're seeing is normal operation.
Old 06-19-2010, 08:51 PM
That is the problem it cools fine while driving but does not cool when at idle. the comp. will only stay in-gauged for about 5-10 seconds
B
Old 06-19-2010, 08:55 PM
Rep:1909
Ok, that's an important symptom. Most likely your condensor fan is inoperative for some reason and that's why you only have ac cooling while moving.
Old 06-19-2010, 09:40 PM
GUAMANIAN GUAMANIAN is offline
Rep:24
GUAMANIAN is on a distinguished road
I am experiencing the same thing. I thought it was a Dodge thing. My 93 Plymouth Sundance used to do the same thing. Cold when moving but warm when idling for more than a few minutes.
Old 06-20-2010, 02:01 AM
Thanks Randy. The condenser fan was the problem...
Brent
Old 06-22-2010, 11:25 PM
CamoBoy34 CamoBoy34 is offline
Vehicle: 2004.5 Dodge Ram 2500
Rep:12
CamoBoy34 is on a distinguished road
my is doin the same thing and this is probably a stupid question but where is the condenser fan at? and im new to dodge and have only had it for about a month now
Old 06-22-2010, 11:56 PM
Rep:12
nevermind i wasnt thinkin ha and i found it and mines not workin either what do i start checking?
Old 06-23-2010, 10:13 AM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:71
latitud will become famous soon enough
It seems common for the condensor fan to stop working..I have read and heard that it can be due to ice forming in the bottom of the shroud during the winter and this stops the fan from turning and either burning up the fan motor of blowing the fuse.
First things first is to check the fuses. I checked the fan motor by unhooking the connection and then jumping a pigtail wire directly from the battery to the fan. My fan was shot. You can buy the entire motor/shroud assembly for about $75. Its pretty easy to replace and you will have to cut the old shroud to get it around the a/c line that runs into the condensor...and cut the new one to get it back on. Takes about an hour to change out. Make sure to drill some drain holes in the bottom of the new shroud before you put it on.
2010 Dodge Ram, 5.7 Hemi, Crew Cab
