A/C question - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 06-23-2010, 10:18 PM
CamoBoy34 CamoBoy34 is offline
Vehicle: 2004.5 Dodge Ram 2500
Rep:12
CamoBoy34 is on a distinguished road
if you have pictures of the cut shroud could you post them please because i can get a little cut happy and cut to much away
Old 06-24-2010, 08:07 AM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:78
latitud will become famous soon enough
I will take some and post them up, but once you see it..it really is simple. You only end up cutting a very small piece on the old one, however the new one requires a little more as the shroud is shaped differently in the same area.
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 06-25-2010, 12:05 AM
Rep:12
ok thank you and i havent had alot of time to mess with it now cuz of wheat harvest and i appreciate all the help
Old 06-28-2010, 05:15 PM
GUAMANIAN GUAMANIAN is offline
Rep:24
GUAMANIAN is on a distinguished road
OK, called around for replacement fan assembly only to find out no one carries them and will have to order. $118 including tax from local parts store. Then I decided to call the stealership just to see how much they would rip me off only to find out they no longer support this assembly and I must purchase a retro fit set at the sum of............................wait for it..............................$240 plus $15 wiring harness adapter.
After a few cuss words and some lunch I decided that since the fan motor was shot I could take it apart and see just what might be wrong. I have dealt with electric motors before (rc cars) and figured they were all the same. I was right, they were just with bigger parts. Once I took the rear cover off I saw what the problem was. One of the wires that attach to the brushes had come off (or shall I guess to say melted off due to the heavy load from what you all talk about). Needless to say, I rigged a temporary solution (till I get a soldering iron), put the motor back together and re-install everything.. Problem fixed, started the truck turned on A/C and plugged the fan in and WALA!!!! Motor turnes and A/C is cold on idle again.. YEAH!!!!!
Old 06-30-2010, 12:28 PM
KSutherland KSutherland is offline
Vehicle: '02 Ram 1500 QC 5.9L
Color: Blue
KSutherland is on a distinguished road
I have that fan problem right now also.
Old 06-30-2010, 12:49 PM
latitud's Avatar
Rep:78
check out ebay...it comes with the harness...$75 delivered.
Old 07-06-2010, 05:20 PM
latitud's Avatar
Rep:78
sorry it took so long to post the pics but here they are. It's hard to tell exactly what is cut, but when you do the work, you will see it plainly.
Old 07-06-2010, 06:52 PM
Nice fix . Not many people go through the process of finding out what failed . Some rep for ya .
Old 07-06-2010, 07:24 PM
Rep:12
thanks for the pics and i just went and bought the fan motor from the dealership today for $129 the whole assembly was $197 so i passed on it
Old 07-06-2010, 07:47 PM
latitud's Avatar
Rep:78
I got the entire assembly for $75 delivered and it is less than 1 hour worth of work..trickey, but not impossible. I simply used a coping saw to cut the old shroud from around the a/c line to get it off...it is only 2 bolts mounting the shroud to the crossbrace and 4 bolts holding the shroud to the condensor.
