Old 06-19-2010, 01:00 AM
StormTrippinFiVe9 StormTrippinFiVe9 is offline
Vehicle: 1999 Dodge Ram
Trim Level: Sport; Blue decals
Rep:17
StormTrippinFiVe9 is on a distinguished road
Send a message via AIM to StormTrippinFiVe9
Question Squeak sound while steering?
Sup guys i'm pretty confused on whats happening with my truck, but sometimes when i fully steer the wheel one way or another while im backing out or something i will get this irritating squeak or noise of somesort. I really don't know what the problem could be haha.
also, sometimes after coming after a full steer ill get a weird slight vibration sound coming from the front wheel area while the truck is correcting itself straight. Any ideas on whats wrong?
Thanks a lot!
Old 06-19-2010, 01:06 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Just a guess, but sounds like you may need some front end service. I've heard squeaking that matches your description, and it usually is either worn parts or lack of lubrication. As we are talking about a part of the truck can cause major issue if something breaks or seizes, I'd recommend having a reputable shop check it over.
brad
Interested in one of my mods?
Old 06-19-2010, 09:30 AM
Rep:1890
Break out the grease gun and spray lube and get busy on the front end. I'm guessing its just a dry bushing or joint in the steering. Also sounds like it may be time for an alignment.
Old 06-22-2010, 03:00 PM
Rep:17
yeah i know the front wheels need alignment because we had some road work done down where i live and knocked off those clamp on wheel weights.
I ordered up some sway bar bushings and end links and im installing a suspension lift that comes with shocks, front coils, and steering stabil. shock.
i hope that will fix everything!
