Old 06-19-2010, 03:27 AM
simply2cool's Avatar
simply2cool simply2cool is offline
Vehicle: 2007 Dodge Ram 1500
Trim Level: Quad Cab SLT BigHorn
Color: Brilliant Black Pearl
Rep:44
simply2cool is on a distinguished road
Default Head Unit Swap Question?
I have the REF Single cd with sirrius radio installed in my 07 Ram 1500. If I were to do a head unit swap with another OEM Head Unit. Is it a simple plug and play swap? Would I still have the same satellite esn or would it be different?
2007 Ram 1500 Quad Cab, SLT Big Horn, 4.7 Flex Fuel, Volant CAI, Hypertech Max Energy, Westin Nerf Bars, MYGIG upgrade.
Old 06-19-2010, 01:28 PM
05atlanticblue's Avatar
05atlanticblue 05atlanticblue is offline
Vehicle: 2005 dodge ram
Trim Level: sxt
Color: atlantic blue
Rep:197
05atlanticblue has a spectacular aura about05atlanticblue has a spectacular aura about
the sirius units are spearate from the decks. mine was plug and play
Old 06-19-2010, 01:47 PM
You just need a sat radio plug in at the back but if you go stock for stock MOPAR, most units have this. You would use the same sat receiver that's already in your truck.
If you go with a larger DIN head unit, such as I did, you just need a new center bezel.
Old 06-20-2010, 12:59 AM
Rep:44
Thanks for the information. I thought they were separate units, but wasn't sure.
Old 06-20-2010, 01:02 AM
Rep:44
I would like to do the same setup. Do you have any pics of yours. I would love to go to a mygig head unit.
Old 06-20-2010, 01:25 AM
ScatPak07's Avatar
Rep:970
Yea if you are going with a diff headunit just make sure it has the Sirius plug in
Old 06-20-2010, 02:43 AM
Rep:44
Does anyone know if the REN units with sirrius(08-10) will work with my 2007?
Old 06-20-2010, 12:46 PM
I went with the REC/NAV head unit when I did my swap. With the exception of the button orientation when compared to the MyGig, it would look similar to this:
Before:
1.5 DIN / DD size comparison:
1.5 DIN head unit and small cubby exposed:
Stock opening, ready for new head unit. Notice the number of mounting holes you have to play with:
After:
Old 06-20-2010, 11:11 PM
Rep:44
Thanks for the pics. It looks great.
Old 06-20-2010, 11:31 PM
I get to swap this one out again...I ended up with a bum unit. Damned eBay!!!
I have another REC/NAV in my 300SRT8 which, when I pick the new audio gear for that vehicle, I'll put in the truck.
