No control of A/C - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Diesel Forums!
Dodge Caliber
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Place your Ad Here!
Old 06-19-2010, 06:11 PM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
Default No control of A/C
My a/c works very well, except for the temperture control. It seems like there is no mid point. I turn the temperature dial till the a/c shuts off, then warm air comes out. When I turn it back to colder, it's freezing. There is no mid point. So I'm wondering if the the temperature control is bad. It seems like some kind of reostat, as I turn it, it has clicks as it is turned. Please advise if anyone has had a simular problem.
Old 06-19-2010, 06:16 PM
Resident Technician
Rep:1915
What year is your truck? Different body styles use different control systems.
Old 06-20-2010, 12:22 PM
Vehicle: SRT-10
Rep:434
It's a 2000 Dodge Ram 1500. See attached picture of controls
Old 06-20-2010, 12:23 PM
I wonder if the switch has some dust or carbon on the backside contacts.
Old 06-20-2010, 01:17 PM
Resident Technician
Rep:1915
For some reason it would seem the blend door isn't stopping at any midpoints, only full hot or full cold. The problem is I don't know if it's most likely a motor or the controller (knob).
Old 06-20-2010, 02:20 PM
Vehicle: SRT-10
Rep:434
I took the dash instrument cover off, and pull teh control. It looks like all one unit. Not sure, can it be taken a part to even check the contacts for carbon build up? Plus where would I find the "door" that is suppose to modulate between the flow of cold and hot? So ther is some kind of motor on it?
Old 06-20-2010, 02:54 PM
Resident Technician
Rep:1915
The blend door is in the HVAC unit and the dash and box have to come out for access.
Old 06-20-2010, 05:22 PM
krb krb is offline
Gender: Not Specified
krb is on a distinguished road
To get the doors,the dash and steering column have to be removed first.Then the HVAC unit needs to be removed from the firewall.
I just went thru this to replace a broken coupling that is between the blend door actuator and blend door.
The door was stuck with the heat on.
Old 08-10-2010, 10:43 PM
Vehicle: SRT-10
Rep:434
You've got to be kidding. Remove the steering column!! OMG Are there step by steps anywhere. Cause now it's stuck in heat mode
Old 08-10-2010, 11:06 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Google service manual for your truck.
Brian:
