Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 08-11-2010, 12:01 PM
Mtx's Avatar
Mtx Mtx is offline
Vehicle: 97 Dodge 2500
Trim Level: 2500 4x4
Color: hunter green
Rep:16
Mtx is on a distinguished road
i wouldnt mind that!
Old 09-27-2010, 02:31 PM
mrsamtz mrsamtz is offline
Vehicle: 2000 Dodge Ram
Color: Garnet Red w/Gold
mrsamtz is on a distinguished road
HEATER TREATER......guy in texas.....search it......
Old 09-27-2010, 02:42 PM
Rep:2657
hope it helps
Old 09-30-2010, 09:56 PM
JoeDodge JoeDodge is offline
Vehicle: 1998 quad cab 5.2 soon 2B 5.9
Color: blue
JoeDodge is on a distinguished road
Sounds like the coupling between the blend door motor and the blend door is cracked. The motor and coupling can be replaced WITHOUT removing the dash or A/C housing. The motor is located on the bottom of the A/C case above the passengers left foot. It is black, about 2" x 2" & 1" thick. Pull back the carpet below the motor. Using a long knife, remove a section of the under carpet insulation below the motor. There are 2 screws attaching the motor to the A/C housing. Using a 90 degree phillips screwdriver, remove the front screw. Then using a very stubbly phillips remove the last screw. Pull the motor straight down. The brown coupling may stay in the A/C case or may come out with the motor. If it is in the case, use a pair of needle nose pliers to remove. This coupling is available at your Dodge dealer. I can get you the part # if needed. To install, fit the new coupling into the case onto the blend air door shaft. You should be able to be able to twist the coupling and feel the door moving. Install the motor and install the rear screw first. Crank the engine and allow to warm up. Move the temp knob to see if the temperature goes from hot to cold and back. You may have to remove the motor and and reindem the motor on the coupling to get the temp span correct. Reinstall the other screw. JoeDodge
Old 10-02-2010, 08:39 AM
Color: blue
You may have to remove the motor and and reindem the motor should read reindex
Old 10-11-2010, 12:10 PM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
Thanks, Joe Dodge. I just followed your instructions, and pulled the blend door motor, and sure enough, its was the coulpling. It was broken. Called the dealer, they have 4 in stock. But just for that little piece of plastic, it's $15.00. Thanks for the info, your were are great help.
Old 10-21-2010, 12:07 AM
Default Solution!
HEATER TREATER on EBAY.......that was the fix for mine!
Old 11-26-2010, 12:35 PM
Vehicle: SRT-10
Rep:434
Okay, bought a new plastic link between the blend door and the actuator motor. Went to put it in and try and align it up, so I plugged the motor back in and started the truck. The motor continues to go non-stop. Tried stopping it with my fingers, no-go. When I adjust the temperature control it stops, and when I move it towards cooler, it moves in the other direction. But what makes stops it. If I install the plastic link, it will continue to drive and bust the new link. What else could be wrong?
