The 30k Service - The Real Truth - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 06-20-2010, 08:55 AM
Resident Technician
Rep:1915
Exclamation The 30k Service - The Real Truth
The 30k service - what should really be done? The simple answer is in your glove box. The things that really need to be done and will ensure your warranty will remain intact are listed right there in the maintainence section. This is the bible as far as the service schedule goes and nobody can tell you any differently. Sure, service departments and independent shops will often try to sell these packages because some vehicles still require a lot of these services every 30k and the people selling them haven't broken the habit of trying to sell them at those intervals. Below is Chryslers official policy regarding fluid flushes for 2005 and newer vehicles.
Chrysler Group vehicle fluid systems do
NOT require regular flushing. These systems
include: engine oil, transmission oil, axle lube, brake fluid, power steering fluid, and
refrigerant. The only exception to this requirement are published in the vehicle
maintenance schedules, e.g. engine coolant.
Exceptions to this recommendation include only those instances where a failure has
occurred and/or the system has become compromised, contaminated or overheated
beyond the normal operating range.
Chrysler Group does NOT recommend aftermarket chemicals to flush the engine,
transmission, brake or steering systems. Chemicals contained in these products can
damage the system elastomeric components, and contaminate the component fluid,
leading to loss of system/component durability and service life. When necessary, only the
original approved system fluid should be used to flush these components using teamPSE®
approved equipment.
If the engine coolant contains a considerable amount of sediment, clean and flush with
Mopar Cooling System Flush, p/n 04856977, or equivalent. Follow with a thorough rinsing
to remove all deposits and chemicals. Refill with a minimum of a 50% mixture of the
specified coolant and distilled water.
Even though I run nothing but synthetic fluids in my truck, I still change them at the recommended intervals. I do the oil every 5k, the diffs and transfer case every 15k, and the transmission, brake and power steering fluids every 30k.
Old 06-20-2010, 10:02 AM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PXR Black
Rep:2477
Smile
Well done Randy , thanks for posting this. The important thing is to have service done according to the schedules laid out in the maintenance section of your owners manual. If you are harder on your vehicle than the average joe better to follow the rough service side.
sales@revelperformance.com
Old 06-20-2010, 10:14 AM
Good stuff, Randy. I agree with the service intervals despite the use of synthetics.
Old 06-22-2010, 01:39 AM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
Oil change at 5,000 miles using synthetic? Wow, that's almost a waste. I run Mobil 1 on all my vehicles minus the Cummins and I wouldn't use that early of an interval, unless I'm taking my cars to the track. I do agree with the intervals of the other fluids as specified, although a little bit longer for me.
Old 06-22-2010, 02:45 AM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
thanks man for posting this
Old 06-22-2010, 02:54 AM
Rep:4281
That is good info there. Guess the only thing I found odd when I bought my truck is there is no light duty/severe duty choice in maintenance schedules for my truck? Heck I was satisfied with getting an extra 2,000 miles out of an oil change since I had always done them every 3,000.
Old 06-25-2010, 10:39 AM
Resident Technician
Rep:1915
Not anymore. I think it was '08 that they went to one schedule.
Old 06-25-2010, 05:05 PM
bloodstripe23's Avatar
bloodstripe23 bloodstripe23 is offline
Vehicle: 2009 Dodge Ram 1500
Color: Inferno Red
Rep:21
bloodstripe23 is on a distinguished road
great info thanks for posting.
Old 06-28-2010, 02:49 AM
Valldar's Avatar
Valldar Valldar is offline
Vehicle: 2006 Ram 1500 - 5.7L HEMI 4x4
Rep:63
Valldar will become famous soon enough
Thanks for the info Randy, I just tipped 32k miles and was working on a list to get done all at once, helped me out a lot!
ERIK
-=UPGRADES=- Focal K2 Component Speakers // 2x Boston G210-44 Subs // 2x JL 500/1 & 300/4 Amps // Rhino Lining Bed // Grillcraft Black Grille // 35w 5000k HID Fogs // 50w 6000k HID Heads // 0 Gauge Engine Wire Upgrade
