dog of a v-10 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Towing
Towing 2nd Gen Dodge Ram Towing Questions
Old 06-21-2010, 01:03 AM
kfe kfe is offline
kfe is on a distinguished road
Angry dog of a v-10
i have a 2000 ,2500,dodge with the v-10. and 57821 miles on it low miles one of the reasons i picked it up. i have had it checked out by dealers, private mechanics looking for solutions to this lack of power with not much change. it has a K&N filter setup on it.a power aid throttle body spacer, a new turbo free flowing muffler and checked out the cat. it was OKed.the r.p.m. at MPH are about 2500 in drive,and OD is about 2300 this seems low to me. it also has taller tires 285/75r16 then stock 265/75r16 this doesn't seam to drastic to me.but i think it is screwing with the p.c.m.? i know the m.p.h. is off. the diff. has this tag info. 52069469aj-ls--------34506242-2 dose this mean it has 3.45 gears? is that the next step to find the towing power i think it should have??
Old 06-21-2010, 11:12 AM
Rep:1625
I see this is your first post, welcome to the forum! Sorry I don't have an answer for you, but hang in there, another member may be able to help
Old 06-21-2010, 02:50 PM
PorkChop's Avatar
PorkChop PorkChop is offline
Vehicle: 2009 ram 1500
Trim Level: sport
Color: brillian black
Rep:75
PorkChop will become famous soon enough
spark plugs comes to mind, im not much for the gear ratios...im still learning them. also, if it came from farm community you may wanna drain the gas and give it a new fuel up...could be moisture in the gas
DODGE the father RAM the daughter!
Old 06-28-2010, 11:09 PM
badazram's Avatar
badazram badazram is offline
Vehicle: 1995 Ram 2500
Trim Level: Laramie Slt
Color: Green
Rep:72
badazram will become famous soon enough
only one cat?, mine has two, just thought id point that out
Common sense is genius dressed in its working clothes
Old 06-28-2010, 11:15 PM
When was the last time it had a good ole fashion tune up . Look around in the glove box and see if you can find any more info on the rear gear . 3.45 doesn't sound right . Also don't forget to stop by the newbie section and introduce yourself .
Old 06-29-2010, 08:38 AM
whi3500mag's Avatar
whi3500mag whi3500mag is offline
Vehicle: 2000 dodge ram 3500 4x4 qcdrw
whi3500mag is on a distinguished road
i would start with a fresh tune up also and go from there i haven't herd of 3.45 gears in these trucks but maybe 3.55 but i would think it would be 3.92 or 4.10 my 3500 has 4.10
