Old 06-21-2010, 07:57 PM
studrudd's Avatar
studrudd studrudd is offline
Vehicle: 2005 Dodge Ram 1500 Hemi SLT
studrudd is on a distinguished road
Default Plugs
I was wondering two things. First of all how often should you change your spark plugs. mine have 66000 miles on them. and do yall have a personal preference on a brand of plugs. Thanks
Old 06-21-2010, 07:59 PM
30,000 is the service interval and NGK's appear to be the favorite with most Hemi owners.
Remember, you need 16 plugs.
Old 06-21-2010, 08:04 PM
studrudd's Avatar
Damn lol looks like im a little over due. would i notice anything performance wise when i change them out?
Old 06-21-2010, 08:06 PM
I think it's a fairly conservative service interval.
Yeah you would see an improvement in power and potentially mileage. Check those plugs and see what condition they are in.
While you change the plugs, check your throttle body. It may be a bit carboned up and cleaning those is always a good idea.
Old 06-21-2010, 08:09 PM
studrudd's Avatar
Awesome. Thank you. Also, my check engine light came on 2 days ago and i had it checked and it said the EGR valve needs to be replaced. What exactly is an EGR valve and would it be bad to be driving my truck while it is bad.
Im a noob when it comes to EFI.
Old 06-21-2010, 08:19 PM
EGR = Exhaust Gas Recirculation
In internal combustion engines, exhaust gas recirculation (EGR) is a nitrogen oxide (NOx) emissions reduction technique used in most gasoline and diesel engines.
EGR works by recirculating a portion of an engine's exhaust gas back to the engine cylinders. In a gasoline engine, this inert exhaust displaces the amount of combustible matter in the cylinder. This means the heat of combustion is less, and the combustion generates the same pressure against the piston at a lower temperature. In a diesel engine, the exhaust gas replaces some of the excess oxygen in the pre-combustion mixture.
The EGR code is caused when the carbon builds to a point where either the sensor can no longer read across the valve or the valve gets stuck due to excess carbon. It's a normal maintenance item.
I'd get it replaced as soon as you can. While it won't cause significant damage to the engine, it can have a detrimental affect on engine performance and mileage.
It's not hard to do, the parts are cheap and it will make that code go away.
Old 06-21-2010, 08:24 PM
studrudd's Avatar
Wow, you are a life saver. I really appriciate everything. Thank you so much
Old 06-21-2010, 08:25 PM
Holler if you need any pics, diagrams or instructions on how to get it out.
Old 06-21-2010, 10:25 PM
^^ agreed^^
Old 06-21-2010, 10:35 PM
ScatPak07's Avatar
Rep:970
Couldnt say anyhting better than Maddog has haha
