Place your Ad Here!
Old 06-22-2010, 09:34 PM
farmboy2500's Avatar
farmboy2500 farmboy2500 is offline
Vehicle: 1994 dodge ram
Trim Level: 2500 reg. cab 2wd
Color: red/black
farmboy2500 is on a distinguished road
Default pcm codes
i have checked on http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
for what the codes are and how to check them but when mine blinks im not sure if it blinks a few time b4 it starts to give me the code or if i have multiple codes blinking so it would be helpful if someone could tell me how many times it will blink b4 or if i just have two codes storred i the pcm.... thanx alot.
Old 06-22-2010, 09:38 PM
It should blink the number of the first code, pause, then blink the number of the second code, pause, back to first cycle.
I suspect you have multiple codes. It's damn confusing.
A lot of auto parts stores will scan your PCM for free. They don't offer diagnostics but at least you'll know what you got going on.
Old 06-22-2010, 09:42 PM
Color: red/black
yeah but its a 94 i dont think it has a hook up for a drb tool... i know it the first and second
didgets but it gives me four numbers b4 it cycles through to give me the 55 code for end of message
Old 06-22-2010, 09:44 PM
There should be an OBD I interface plug somewhere because they have to query the PCM if you get a code. It may be on the computer box itself vs. under the dash.
Old 06-22-2010, 09:46 PM
Color: red/black
k but that still doesn't tell me bout the codes that im getting
Old 06-22-2010, 09:48 PM
Sorry but without being there to see it, there's no way I could translate them for ya. Were you able to get any numbers written down at all? Try just writing down the number of blinks you get in order and maybe we can decipher it.
Old 06-22-2010, 09:50 PM
Rep:4253
What codes are you getting? Then we can help you interpret them.
Old 06-22-2010, 09:54 PM
Color: red/black
cycle key on off on off on.....1 pause 2 long pause 3 pause 2 pause then the 55 end code
Old 06-22-2010, 09:59 PM
so that looks like 12, 32 & 55?
Old 06-22-2010, 10:03 PM
Battery Disconnect
Direct Battery input to PCM disconnected within last 50 ignition key-on cycles. Normal if battery has been disconnected, otherwise check battery power and ground connections.
32**
EGR Solenoid circuit
Short or open in the EGR solenoid circuit. Check for loose, broken, or shorted wire in the EGR valve wiring and connectors. Possible air fuel ratio imbalance not detected during diagnosis.
55
N/A
End of message code. A DTC 55 is used to end all DTC messages. This code does not show on the DRB tool and indicates a completion of the stored codes on the Malfunction Indicator Lamp (check engine lamp).
Fault codes with ** = Check engine lamp will illuminate when the engine is running if this code was recorded.
Have you done a disconnect on your battery or recently experienced a low or dead battery? If you had a low battery or it went dead, it may be a short at the EGR sensor wiring or the sensor itself.
