Old 06-22-2010, 10:23 PM
kingpolarbearz's Avatar
kingpolarbearz kingpolarbearz is offline
Vehicle: 97 2500 4x4
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
kingpolarbearz is on a distinguished road
Default front end eathquake
I have a 97 2500 4x4 extend cab 8' bed diesel 2" leveling blocks in front 3" in back any how, i have new shocks and steer dampner tires are round . i switched front to back to see if it was tire and no dice stayed the same and help would be great thank Keith
Old 06-22-2010, 10:26 PM
Possible death wobble .
Old 06-22-2010, 10:36 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Have the front end alignment checked. Take note of the initial readings.
Do you have any amount of play in your steering wheel?
With the truck parked, if you grad a front wheel and try to wiggle it in the left/right direction, do you hear/feel any thump?
brad
Interested in one of my mods?
Old 06-23-2010, 06:40 AM
Default earthquake
all is tight slighjt pull to rught outher than that it good
Old 06-23-2010, 09:30 AM
ericautopart ericautopart is offline
ericautopart is on a distinguished road
Send a message via AIM to ericautopart
U joint in the front axle may be boring out the hole so it's oblong causing a major vibration. Check the axle shafts. One may even be bent but it's more than likeley a u joint.
Old 06-26-2010, 01:11 PM
kjones kjones is offline
kjones is on a distinguished road
As always, check the cheapest things first (u-joints). Check slop in the slip joint on the front axle; Also check bushings on upper and lower control arms. Put a foot on the brake and apply a little throttle. First forward, then reverse. Can you feel anything pop?
Old 06-26-2010, 01:16 PM
Rep:1885
Did you check the track bar?
