Old 06-23-2010, 12:22 AM
tinniste 079 tinniste 079 is offline
Vehicle: 2005 dodge ram 1500
Color: charcoal grey
Rep:53
tinniste 079 will become famous soon enough
Default 02-05 4.7 to 5.7 hemi swap help
well i have a 2005 1500 quad cab with the 4.7 and its started over heating and ticking and from what i read it sounds like it might end up dying soon. and i was thinkin about the putting a hemi in it... will it just drop in or what will i need to do. and from what i understand for CA smog it just has to be the same year or newwer and if it was offered in it? right? is there any links that anyones done this and have it smog legal
Old 06-23-2010, 12:18 PM
whitevamp whitevamp is offline
Vehicle: 2010 Ram 1500 Crew 4x4
whitevamp is on a distinguished road
to do an engine swap you will also need to replace the computer ( brain ) aswell , and for direct fit im not to sure on that one, but they should bolt up to the trans the same, as for motor mounts they might be different.
ohh and i allmost forgot you will most likely need to replace the wireing harness under the hood, as i beleve there will be different/more/, and different locations of sensors and such
Old 06-23-2010, 01:56 PM
05atlanticblue's Avatar
05atlanticblue 05atlanticblue is offline
Trim Level: sxt
Color: atlantic blue
Rep:197
05atlanticblue has a spectacular aura about05atlanticblue has a spectacular aura about
it's a lot of work, a lot! your best bet is to find a wrecked 5.7 ram and grab everything.
that being siad, check this out -
hot rod put a big ol hemi in a once 4.7 equipped ram
http://www.hotrod.com/projectbuild/1...500/index.html
Old 06-23-2010, 05:41 PM
Rep:53
sweeeet thanks haha as far as finding a wrecked one that should be simple my dads friend owns a junk yard
Old 06-23-2010, 05:46 PM
I agree...it's more than a simple swap and whitevamp has the right of it. Engine, computer, harness, injectors, throttle body, sensors and, potentially, the tranmission & TCM that goes with it.
Then think about motor mounts, front suspension/springs, etc...
It can be done!
Old 11-18-2010, 05:04 PM
TMuns TMuns is offline
Vehicle: 2002 Dodge Ram 1500
TMuns is on a distinguished road
tinniste - Did you ever do the swap? I'm trying to put a 2003 5.7 hemi into a 2002 with a blown up 4.7.
Old 11-18-2010, 11:20 PM
wester399's Avatar
wester399 wester399 is offline
Vehicle: 2006 Dodge Ram 1500
Rep:100
wester399 will become famous soon enoughwester399 will become famous soon enough
for the price of the crate engine and the other parts its going to take you can likely buy a 2005 to 2008 hemi ram lol.
Old 01-14-2013, 12:00 AM
xXHeatscoreXx xXHeatscoreXx is offline
Vehicle: 2002 1500 4.7
Color: charcol
xXHeatscoreXx is on a distinguished road
Hey guys I'm curious. I have a 2002 dodge 1500 with a 4.7 and it's standard. I don't like the 4.7 at all on the highway. I couldn't pass someone if I wanted too. Truck has 250k and have thought about doing a rear mount turbo or a hemi swap. I've found a few forums and 100 different answers about swaps. Will a hemi swap into a 4.7 with a manual or does the granny need to be swapped aswell.
