New inj pump, now lift pump does'nt work - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 06-23-2010, 12:03 AM
Stewartforever Stewartforever is offline
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Stewartforever is on a distinguished road
Default New inj pump, now lift pump does'nt work
I just installed a rebuilt vp44 injector pump on my 1998 1/2 cummins equipped dodge. It's an automatic tranny. I removed the old injector pump and also removed the fuel filter and cleaned out the water separator. I installed the new injector pump and also a new fuel filter. I did plug back in the connector to the injector pump, the throttle position sensor, and the water sensor in the separator. Now when I key the ignition the lift pump in the tank does not turn on. I looked through the book that I have ( which is'nt very good ) and it said a dark green wire with a black trace was the lead for the fuel pump. I found a dark green wire in the loom under the truck but found now voltage when the ignition was keyed. Any help would be greatly appreciated either a wiring diagram or possible reasons why my lift pump suddenly does'nt work, I was able to drive the truck into the garage but now nada.
Old 06-25-2010, 03:48 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
i see that this is your first post so hello and welcome, as for your problem i am sorry i cant help you, but i am sure someone here can
Old 07-26-2010, 11:15 PM
cjames cjames is offline
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
cjames is on a distinguished road
im not really the guy to talk to but i do know that on 98-02 24 valve cummins have falty lift pumps that go out and take the vp44 with em.... normally its the lift pump that goes first though.... i guess im suggesting an aftermarket lift pump but i couldnt even tell you for sure if thats the issue as i dont own a 24 valve cummins
Old 08-27-2010, 10:36 AM
johnny mac johnny mac is offline
Vehicle: 2000 dodge ram 2500
Trim Level: laramie slt
Color: red
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
johnny mac is on a distinguished road
I have a '00 cummins and have been told to watch out for just what cjames was talk'n about. The lift pump goes first and it takes out the injector pump. When you replace what you did does the system need to be primed? Interested in what you find out and good luck.
Old 08-27-2010, 11:06 AM
Resident Technician
Rep:1915
Newer systems are self bleeding but older ones need to be manually bled. I don't recall offhand what year the self bleeding systems began though.
Old 08-27-2010, 02:43 PM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:78
latitud will become famous soon enough
If the lift pump was bad and caused the injection pump to go...when you opened up the system and installed the new injection pump, there is no way to get fuel to the injection pump. You said "in tank" pump. Did you perform a TSB to replace the lift pump on the block with the in tank version? I had an 02, so not sure how much a 98 is similar.
2010 Dodge Ram, 5.7 Hemi, Crew Cab
