Old 06-23-2010, 08:32 AM
got hemi's Avatar
got hemi got hemi is offline
Vehicle: 2004 Dodge Ram
Color: Platnum Metalic / Silver
Rep:40
got hemi is on a distinguished road
Default antifreeze, which kind/brand???
i'm in the process of changing out all my old fluids, near that 100k mark. so i thought i'd get a jump on things and got all my oils and lubes and stuff from amsoil. but has any one used the amsoil antifreeze?? normally i'd reference the owners manual, but at $134 for antifreeze is it really worth it?? the "stock" antifreeze is different than what the amsoil stuff is, and at the high price im leery of doing it. any info would be appreciated thanks.
Mr. Grimm
Mod list here :
http://www.ramforumz.com/album.php?albumid=130
Old 06-23-2010, 09:25 AM
Rep:4072
Personally, I can understand why people use Amsoil oils/diff fluid, etc., the info is out there as to the advantages there, but IMO, I just don't see where Amsoil coolant is that much better than what you buy at the local auto parts store. No, I don't buy the "store brand," but $134 for coolant seems a bit excessive, almost like at that point you're just paying for the name, but that's just my .02 and perhaps someone on here has some info on that.
Old 06-23-2010, 09:35 AM
Use the recommended coolant spec and mix of water to antifreeze for your area.
I know folks will tout the advantages of different mixes and brands with additives but, hey, if ya got no problems with your cooling system and it's had recommended fluids in it for 100K miles, why not continue with what works?
In other words, if it ain't broke don't fix it...
just my 0.02
Old 06-23-2010, 10:02 AM
got hemi's Avatar
Rep:40
agreed with the both of you. it does seem rather excessive, and its antifreeze, there cant be that much of a difference in amsoil to "regular" antifreeze. im gonna save the money and flush/fill with what should be in there, just needed to know if there was THAT much of a difference to be paying such a high dollar amount. thanks cajun & maddog for the input
Mr. Grimm
Mod list here :
Old 06-23-2010, 10:55 AM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:71
latitud will become famous soon enough
Chrysler requires a specific antifreeze called HOAT (G-05). The only aftermarket supplier that I have seen that makes it is Zerex G-05 and it comes in a copper colored bottle. Napa sells it.
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 06-23-2010, 11:39 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Amsoil is propoylene glycol, vs. ethylene glycol. Not sure of the advantage, but my luck, after that antifreeze change, I would probably blow a hose and lose all of it. I like Amsoil products, but I'm not sure about that much for coolant, considering the propensity of losing most of it with a leak. At least with oil, trans fluid, etc, you can just top it off.
Old 06-30-2010, 12:02 PM
MS520's Avatar
MS520 MS520 is offline
Trim Level: Hemi
Rep:109
I use 50/50 of whatever is on sale that week if I need to buy coolant.
Mike
'04 Ram
"Yea its got a hemi!"
Old 06-30-2010, 12:03 PM
Rep:1845
If you're not using HOAT, don't be surprised when your cooling system starts having problems.
Old 08-02-2010, 02:35 AM
hemiram66 hemiram66 is offline
hemiram66 is on a distinguished road
Mopar fluids aren't nearly that expensive. I'd just head to my dodge dealership and grab some because then you can say its 100% Mopar.hehe
Old 08-02-2010, 04:06 AM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
And...if you live in an area that hardly gets below 50* ever...then, you can do like I do is run a 70% water, 30% coolant for better cooling
But..if you live where it freezes...don't do that.
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
