Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Washing & Waxing
Washing & Waxing Washing and Waxing your Dodge Ram! Talk about it here!
Old 06-23-2010, 10:57 AM
NIGHTRUNNER2006's Avatar
NIGHTRUNNER2006 NIGHTRUNNER2006 is offline
Vehicle: 2006 Dodge Ram 1500 hemi
Trim Level: Night Runner edition
Color: Brilliant Black w/pearl
Rep:27
NIGHTRUNNER2006 is on a distinguished road
Default Suggestions to remove a scratch?
I have kinda like a swirl scratch on the side of my truck as if someone was reaching into the with their keys attached to their belt loop type scratch. I went to the local car detail shop and they told me it was fixable/buffable however they want to charge like $75 so I was thinking it something i can do myself. Whats on the market that will fix these type of inperfections?
Also considered using a claybar on the paint, How does this work?
thanks guys
sean
Old 06-23-2010, 11:05 AM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Depends on well your buffing skills are, and if you know how to use a rubbing compound, which in my opinion works the best. I am sure there are other ways.
Clay barring is easy, just time consuming. You spray on the quick detailer wax stuff, rub with the clay bar, wipe it down. Just follow the directions on the package its pretty simple
Old 06-23-2010, 11:40 AM
whi3500mag's Avatar
whi3500mag whi3500mag is offline
Vehicle: 2000 dodge ram 3500 4x4 qcdrw
whi3500mag is on a distinguished road
i have to agree with werm get ya som trurtle wax rubbing compound in the green and white tub and an orbital buffer it may take ya a few times over but it should do the trick!
Old 06-23-2010, 04:09 PM
Rep:27
Ive already got some of the turtle compound BUT i dont have a buffer. But yall say it should do the trick so ill give it a shot. Personally I like Ice products the best but they are a little pricey.
Old 06-23-2010, 07:29 PM
Rep:1930
You can hand buff it too with that stuff.
Old 06-24-2010, 09:47 PM
Smitty's Avatar
Smitty Smitty is offline
Vehicle: 2009 Dodge Ram 1500 4 x 4
Smitty is on a distinguished road
A clay bar will do absolutely nothing for scratches and I would avoid that rubbing compound all together. I can't think of a single reason to use that turtle wax compound, you may as well use a random orbit sander on your paint. The clay bar is designed to remove contaminants from the clear coat, it does not have the capability to correct damage in the finish. The only way to properly remove the scratch, and fully restore the surface is with a decent polisher and cutting compound.
Old 06-25-2010, 06:43 PM
Leadfootluke Leadfootluke is offline
Vehicle: 1998 Dodge Dakota
Rep:276
Leadfootluke is a jewel in the roughLeadfootluke is a jewel in the roughLeadfootluke is a jewel in the rough
Thank you! I have recently seen dozens of posts advising the use of Turtle Wax products. For one, there is no turtle wax product worth purchasing that you could not get from another brand that works better. Compounds are meant to do heavy cutting, and if you use it, you will effectively be using 2000 grit sandpaper on your finish. Then you will need another polish to remove that, and so on.
To the OP, post pictures if you could. Some scratches will require a repaint, others machine polishing, and others hand polishing. If you do go get rubbing compound, just be warned you are creating a much bigger mess than you know. It may look good, but the compound will induce millions if micro-marrings on the finish.
