Old 06-23-2010, 04:16 PM
verytalonted verytalonted is offline
Engine: 1989-1993 360ci (5.9L) Cummins diesel I6 160hp 400lb/ft
verytalonted is on a distinguished road
Default Trouble with aftermarket HU and Infinity system.
Ok I am resaerching this for my bro-in-law.
He has a 2002 Ram 1500 QC and has an aftermarket HU and has replace all the door speakers.
This truck did have the Infinity system.
His back door speakers work fine, but the front door speakers only play the bass from the audio, no treble at all.
How do we make it use the 4 door speakers and play treable and bass on all the 4 door speakers????
Thanks guys!
Old 06-23-2010, 04:33 PM
BAMA13NC BAMA13NC is offline
Vehicle: 2006 Dodge Ram
Trim Level: SLT Quad Cab
BAMA13NC is on a distinguished road
was the infinity amp removed from the system. The infinity amp runs the rears full range and runs the front doors mid bass/bass only. Check and see if the ifinty amp is in the system you will have to remove it from the system. You can also find the amp and run the front channel dash speakers to the tweeters on your speakers. I had to do that everytime someone had their jeep grand cherokee with the infinity system wanted to put coaxials in their front doors. I did audio installs for about 3 years and got real used to that problem. Hope this helps.
Old 06-23-2010, 04:50 PM
Yup, it's the amp. Mine's gone. I upgraded recently to a Mopar accessory amp, made by Kicker to fit into the stock location. It's also plug compatible with the stock harness. No special adapters needed.
MOPAR part number is 77KICK18AB and I got it from an online authorized MOPAR parts dealer. It is NOT available directly from Kicker or any aftermarket audio shop that sells Kicker.
Old 06-24-2010, 09:34 AM
As far as I know the Infinity amp is still in there.
All we have done is bought a aftermarket harness that plugs into stock on and wired the HU to that harness.
All we want is door speakers making hi-s and lows.
Old 06-24-2010, 12:59 PM
you would have to run wires into the doors and actually cut the wires on the coaxial probably right next to the spade terminal (depends on what speakers you are replacing with) and the run those wires directly to the amp (if you do not want the dash speakers operating) or to the speakers in the dash. Then you would be able to test the impedance of the wiring. If it drops to low then you can run them in series and not over load the amps stability. Then you would have the dash playing your highs ( if you decide to utilize them also) and the doors playing mid bass and highs. It sounds alot harder than it actually is. But I have had real good experiences running them both ways, just depended on what the customer wanted and wanted to pay for. Hope this helps some I cant remember how hard it is to remove the dash piece to get to the speakers on the dash. If I can help anymore let me know
Old 06-25-2010, 10:58 AM
Do you have any pics/diagrams/etc. that would be a visual aid to you insructions?
Old 06-27-2010, 07:40 PM
what portion do you want to do, the use of the amps or bypassing? either way should not be that hard.
Not to be nosey, where are u located. I am in Norfolk, Va if you are close I would be able to show u.
Old 06-28-2010, 09:12 AM
No I'm down in San Antonio, TX.
But basically we need to get the front door speakers to play all sounds, dont' really want to use the amp/filter as it just seems to complicate the whole thing.
I think we are gonna just run our on wires to the doors.
