Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 > Exhaust
Exhaust 5.2L Wxhaust Discussion
Old 06-23-2010, 05:48 PM
cledry cledry is offline
Vehicle: 1998 Ram 1500
Rep:12
cledry is on a distinguished road
Default help installing Magnaflow catalytic converter
I just received a Magnaflow cat but have a question. It comes in two pieces, the main piece bolts on at the passenger side manifold and then there is a pipe that bolts to the driver's side and looks like it slip fits into the cat. However I cannot get it to slide in. I know it needs to be tight and I made sure both pieces are round and free of burrs. I suppose I could heat the one side up to expand it a bit. Anyway I called Magnaflow and they claim both pipes are the same diameter and need to be butt welded, but they are definitely not the same diameter.
Old 06-23-2010, 07:15 PM
TenneSST's Avatar
TenneSST TenneSST is offline
Vehicle: 1998 Dodge Ram
Trim Level: SS/T
Color: Black/Silver stripes
Rep:134
TenneSST will become famous soon enoughTenneSST will become famous soon enough
I have the Magnaflow cat on my truck. That pipe slid right in. Mine is definitely not butted together. You can clamp it or weld it like I did.
Kevin I.
http://www.ramforumz.com/image.php?type=sigpic&userid=5052&dateline=1301683  967
Old 06-23-2010, 09:58 PM
Rep:12
Yeah, the guy at Magnaflow is wrong. I took my angle grinder and chamfered the down pipe and it slid in the cat part, very tight but that is good. I will likely get it all bolted together and run it down to my friend's shop and let him weld it up. Pretty poor tech support. I'm also going to let my buddy do a better job on the heat shield welds which aren't that good.
I'm going to put a Flowmaster 40 series 3" in dual 2.5" out that I have laying around and probably dump it out the side with dual pipes ahead of the rear wheel to save a bit of cash for now.
Old 06-23-2010, 10:00 PM
ughhhh...I hate parts that don't fit right and I hate poor customer service a lot more!!!
Old 06-23-2010, 11:20 PM
TenneSST's Avatar
Trim Level: SS/T
Rep:134
Mine fit together pretty good. Just make sure when you cut your factory cat off, leave enough pipe. Cut it off directly behind the cat. Even doing that, I barely had enough.
Kevin I.
Old 06-24-2010, 12:49 PM
Rep:12
Thanks for that tip. It probably won't matter since I am getting rid of the stock muffler too.
