Old 06-23-2010, 06:21 PM
Dodgeuser's Avatar
Dodgeuser Dodgeuser is offline
Vehicle: 2015 PowerWagon
Color: Maximum Steel
Dodgeuser is on a distinguished road
Default Sagging doors
Has anyone used a door hinge repair kit from any company like LMC?
I got one to use on my drivers side door and the pins didn't even come close to being the right diameter. they were to big and the bushings were also. Has anyone had a similar experience?
Old 06-24-2010, 10:04 PM
Rep:1882
I've replaced pins and bushing with great success before, but I can't recall who made them.
Old 06-28-2010, 06:28 PM
dirty97ram dirty97ram is offline
Vehicle: 97 ram 1500 ext cab short bed
Color: bedliner
dirty97ram is on a distinguished road
i had the same problem all the ones i could find were either to big or to small so i just drilled my hinges out to make the bigger one fit and now my door dont sag anymore
Old 08-21-2010, 11:18 AM
mlrtym's Avatar
mlrtym mlrtym is offline
Vehicle: 1994/98 Ram 2500
Trim Level: SLT Laramie
Color: Flat Black
Engine: 1994-1995 359ci (5.9L) Cummins 12-valve Diesel I6 175hp 420lb/ft(manual), 160hp 400lb/ft(auto)
mlrtym is on a distinguished road
I just did this to my truck. I was lucky, because the body is a 98. from 94-97, there is no kit out there for the pins. from 98+, there is a kit with 2 different pins. one for the hinge, and the shorter one for the indexed lever thinggy that keeps the door open. both pins come with bushings. they were a perfect fit. i got mine from NAPA. $13/hinge. These may work on the older hinges, but you may have to drill out the holes.
It is better to let one think you a fool, than to open your mouth and remove all doubt.
Old 09-20-2010, 10:02 PM
rph1's Avatar
rph1 rph1 is offline
Vehicle: 1997 Dodge Ram
Trim Level: Sport w/ SLT decor
Color: Poppy Red
rph1 is on a distinguished road
I have a 1997 and I ordered mine from federated auto parts, they were some no name brand for like 4 dollars since mopar doesn't make them for a 1997. I knew they were over sized so I took the truck to a body shop and the one was the right length but the other one was too short. So he used his own. It wasn't too bad for the body shop to do it, only $100 cash
Ryan Herring --> 97' 2500, 360, 3.55
Old 10-25-2010, 01:29 PM
FloridaCracker352's Avatar
FloridaCracker352 FloridaCracker352 is offline
Vehicle: ram 1500 extcab 4x4 1998 dodge
Trim Level: larmine slt
FloridaCracker352 is on a distinguished road
Send a message via AIM to FloridaCracker352
i have a 98 and my doors sag too not real bad but they sag so im going to go to a junk yard and get hinges off of another ram. i don't want to get crazy with lambo door hinges but theres a wrecked durango with lambo hinges on it and they want 25 bucks for both.. thats a pretty good deal i guess?
Old 10-25-2010, 01:48 PM
Rep:2640
http://www.jimsautoparts.com/mopar_p...erior.htm#door hinges
Most sagging doors are due to hinge failure which is due to pin or bushing failure. These hinge repair kits offer an easier and more cost effective way of repairing those hinges back in to working order. Each kit repairs one hinge and contains one zinc and yellow dichromate plated grade 8 bolt, two self-lubricating brass alloy bushings, one zinc plated spin lock nut and one zinc plated internal lock washer.
MP-20544 1994-2003 Dodge Ram 1500/2500/3500 Pick Up $ 24.95/kit
Jims seem to carry a bunch of the older Ram parts, as well as the newer Ram parts, like the locking tail gate parts & some body parts for Rams
Old 10-25-2010, 04:33 PM
Topdown Topdown is offline
Vehicle: 2008 Dodge Ram 2500 Mega
Rep:44
Topdown is on a distinguished road
25.00 for a grade-8 bolt and 2 brass bushings? if my doors didnt sag like an old mans sack I would think that to be laughably expensive, but... they do, and 50.00 doesnt seem too bad, if I dont have to drill out my hinges
1997 White1500 - sold
2008 Silver 2500 Mega Cab
