Rock crawler trans - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-24-2010, 04:54 PM
roon roon is offline
roon is on a distinguished road
Default Rock crawler trans
I have a 1994 dodge ram 2500 with the 5.9 gas engine. It has 16" lift coils on rockwell axles and 44" tires. There is almost nothing original left of this truck other then the motor and trans. Im pulling the motor to rebuild it to a stroker and was curious as what you guys thoughts were on dodge transmissions. I have never torn into a dodge trans and dont know much about them. I need one without overdrive and that is TOUGH! Any thoughts?
2008 DODGE 3500 4X4 LARAMIE
1994 4X4 DODGE RAM 360
Old 06-25-2010, 04:19 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
i wouldn know about your use but the 2nd generation ram trans break according to what i have heard and my trucks is broken LOL
Old 06-25-2010, 09:57 PM
coyote94yj coyote94yj is offline
Vehicle: 1994 Ram 2500 4x4 Cummins
Trim Level: Laramie SLT
Engine: 1994-1995 359ci (5.9L) Cummins 12-valve Diesel I6 175hp 420lb/ft(manual), 160hp 400lb/ft(auto)
Rep:47
coyote94yj is on a distinguished road
Get yourself an SM465. It is a GM(Muncie) transmission but I think it will fit your application perfect.
- Bulletproof(came in 1/2, 3/4 and 1 ton applications)
- Cast Iron case
- 12" case length so it is fairly short
- 6.54:1 first gear(great for crawling)
- Easy to rebuild
- There are loads of them out there
- super cheap (less than $200)
I had one in my Jeep for years behind a Chevy 355 running 38" swampers and loved it. The only down side is 1st gear is not synchronized so you have to come to a complete stop to put it in first but if your going to drive it in town 2nd gear is plenty low enough to start from a stop.
Some more information about it.
http://advanceadapters.com/resources...formation.html
