Old 06-24-2010, 07:53 PM
EBK142 EBK142 is offline
Vehicle: 95 dodge ram, 95 honda accord.
Color: truck black, car green.
EBK142 is on a distinguished road
Default Trailer turn signal not working
There was a short in the right trailer turn signal. There is now no power to the trailer plug for the right turn signal only, everything else is fine left turn signal works, right turn signal and right brake dont work on trailer only, works fine on truck. I am dumbfounded as to what could be causing this, any help?
Old 06-24-2010, 08:06 PM
Rep:1885
Check your fuses. You probably blew out the right side fuse.
Old 06-28-2010, 09:10 PM
Devster Devster is offline
Gender: Not Specified
Devster is on a distinguished road
usually a ground issue
Old 07-14-2010, 09:15 PM
lonewolf lonewolf is offline
lonewolf is on a distinguished road
im having the same problem only on the left side checked fuses there ok
Old 03-28-2011, 06:28 PM
rjr1214 rjr1214 is offline
Vehicle: 2004 Dodge Ram Cummins
Color: Blue
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
rjr1214 is on a distinguished road
I am having the same problem on the left side trailer lights... no parking light, no signal, no brake on left side... all right side trailer functions are ok, everything on the truck works (there is a different wiring system for the trailer that is separate from the truck tail lamps). Did you ever resolve the issue? I'd like to know where the problem was.
Old 03-30-2011, 12:21 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
I can't offer much help to the OP. I don't have any wiring diagram for your model year, and can only offer the same advice you have received from RamTech. Have you checked the output at the trailer plug to determine that it's definitely the truck? Most often the trailer wiring is the problem...seldom the truck, and if the truck, it's usually a blown fuse caused by the trailer wiring.
What year is your truck? I may have a wiring diagram and can offer some fuse #'s or things to check.
I noticed your truck is a 2004. There are a numerous fuses at play.
Fuse 15 (50A) Trailer Park lamps - pre relay
Fuse 33 (20A) Trailer Park lamps - post relay
Fuse 46 (15A) Trailer Left turn
Fuse 47 (15A) Trailer Right turn
Based on your description of your problem, I think the problem is in the trailer. If the Park (tail marker) light works on the right side, then the left side issue has to be in the trailer as this is a common circuit that splits in the trailer. After fixing this, the left turn/brake light might also start functioning. First place I'd look in the trailer in the ground for the left side lighting.
brad
Interested in one of my mods?
Old 03-30-2011, 12:35 AM
Rep:2657
is there a possibility that 2 or more pins in the trailer connections are different than the trucks pins
you might try a different trailer, or use a friends trucks
we run into this problem often when switching one trailer to another on construction sites
Old 03-19-2012, 02:54 PM
SwampCaptain SwampCaptain is offline
Vehicle: 2004 Dodge Ram 1500 4x4
Color: Navy Blue
SwampCaptain is on a distinguished road
Default Right side trailer lights not working due to Tipm possibly being out.
I am not sure if the OP ever found a solution to his issue, but I had same issue and came to the unfortunate conclusion it was my (t.i.p.m.) totally integrated power module. Apparently, although it is fused, the software has a counter that only allows a certain amount of faults before it shuts down that circuit. In my case, and many others I've read, the right side trailer blink/stop light. Can be left also, just depends on which one reaches that limit of faults first. I have read that it can be re-flashed, but isn't guaranteed to work and costs about $125 ish.. The new Tipm cost about $700ish..
So, until i save up that kind of money to have normal working trailer lights, i will spend about $16 on a normal taillight adapter to work my trailer off of my regular taillights and have fully functioning trailer lights at a much cheaper price. Just protect that line so faults don't get sent back to tipm from any shorts in trailer and that circuit gets shut down also.. I searched and read for about a week to figure all this out.
After i made sure all fuses were good, I used another truck on trailer to verify it was my truck and not trailer! Then I traced my factory truck side green wire all the way back to the under hood fuse box using test light to find it was dead even where it came out fuse box. I know this is reviving an old thread, but I hope this helps any future people searching same issue.. Drew
Last edited by SwampCaptain; 03-19-2012 at 02:58 PM. Reason: add paragraphs for easier reading
Old 03-19-2012, 03:42 PM
brad12kx's Avatar
Rep:2581
Your 04 Ram does not have a TIPM. The power distribution is handled through the IPM (Integrated Power Module) and FCM (Front Control Module).
The FCM supplies the trailer light signals to operate the relays in the IPM. Each trailer lighting circuit is handled through a relay and is individually fused. There is no overload sensing or protection other than the fuses.
If the FCM is bad, no surprise. They are a common point of failure and cost about $150. The only thing the IPM does is provide a wire path for the trailer circuits, so failure at this point is 'possible' but highly unlikely.
In 2006, they introduced the TIPM that did electronic switching of the trailer lighting circuits. The TIPM does have load sensing to save itself from destruction in the event of a severe over load like a dead short in the wiring. The TIPM can be reset by removing the battery cable for a minimum of 10 minutes.
brad
Old 03-19-2012, 06:55 PM
Color: Navy Blue
Default ipm/fcm
Thanks Brad, I was about update my post again, cause I continued searching and just read that same thing on dodgetalk. I appreciate your in here as well.. I am still in awe that they wouldn't just leave this kind of vulnerable circuit fused with a user changeable relay since it is trailer wiring we are talking about..
