Old 06-24-2010, 11:04 PM
402 magnum ram 402 magnum ram is offline
402 magnum ram is on a distinguished road
Default need help with lift
I have a 95 ram 1500 4x4 stock lift with 33 inch tires . I wana get some 35 inch tires but i know i will have to lift my truck im wondering whats the smallest lift i could get away with to be able to fit 35 inch tires on my truck even if i have to do a little trimming. Anyway any advice would be awesome thanks alot guys.
Old 06-24-2010, 11:08 PM
Rep:1625
It sounds like you're looking for a leveling kit. With it, you should be able to fit 35s.
Welcome to the forum!
Old 06-25-2010, 10:04 PM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Vehicle: 2005 Dodge Ram 1500
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
You could probably get away with a level kit, might have some slight rubbing! if you don't want to lift it too much do to the ride comfort...which that is what it sounds like, there is the option of a body lift, that will give you enough clearance for 35's, they come at usually 3" of lift without touching the suspension components!
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
Old 06-25-2010, 10:06 PM
If a level isn't enough, you will surely be fine with a 4" lift.
Old 06-26-2010, 01:57 AM
My main thing is I want my tires to be tucked up under the fender wells as possible because I really like the look and I want some 35s i can handle a little rubbing on a full turn thats how my 33s are now. Im on a budget also I just got a new engine for my truck and I also need some other parts so the lift will come last I dont want anything extreme i think if i could get away with a 3 inch kit i would be really happy because I dont think i would have to relocate any suspension parts . Also im putting a v10 in my 95 single cab shortbed 1500 its going to be one heck of a change over so if anybody has ever done this and ran into any snags maybe u could give me some advice on that aswell . thanks alot guys
