Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Body & Interior
Old 06-26-2010, 08:42 AM
Chas's Avatar
Chas Chas is offline
Vehicle: 1996 Dodge Ram 1500
Trim Level: Indy Truck
Color: Blue with White racing stripe
Rep:16
Chas is on a distinguished road
Default Need advise for removing factory radio...
I bought a JVC HD radio for my truck and I plan on installing it today. I need to be sure of the way to remove the face panel on the dash. I see screws in the ash tray area and see them in the cup holder area also......after these are out, is the some I am missing as I look toward the steering wheel area? Does it have clips or such?
Thanks in advance, Chas
Old 06-26-2010, 08:59 AM
Resident Technician
Rep:1909
  1. Disconnect and isolate the battery negative cable.
  2. Open the cup holder and remove the two screws securing the assembly to the instrument panel. Remove the cup holder assembly from the instrument panel
  3. Remove the ash tray. Remove the two screws securing the ash tray bracket to the instrument panel. Remove the tray bracket assembly from the instrument panel
  4. Carefully pry the bezel away from the instrument panel to disengage the retaining clips (see below).
  5. Unplug the connector from cigar lighter.
  6. Unplug the connector from the auxiliary power outlet.
  7. Remove the two radio mounting screws from the front of the radio.
  8. Pull the radio out from the instrument panel far enough to disconnect the wiring and the antenna coaxial cable.
  9. Remove the screw from the radio ground strap and remove the radio.
  10. Reverse the removal procedures to install.
Old 06-26-2010, 10:17 AM
Chas's Avatar
Rep:16
This is perfect!!
Many Thanks dude......
