Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 06-28-2010, 03:52 PM
joshockey joshockey is offline
Vehicle: 1995 dodge ram 1500 2wd
Trim Level: laramie slt
joshockey is on a distinguished road
Default coolant and oil mixing
im pretty sure the oil and coolant is mixing in my old truck seeing how when i pulled the intake the gaskets were shot is this a pretty common issue or am i looking at the more expensive route of having to pull the heads. the truck seems to have good compression and there hasent been any coolant or smoke comeing from the tailpipes.
Old 06-28-2010, 03:56 PM
Resident Technician
Rep:1915
Going to be hard to say for sure since you didn't actually run a compression, leakdown or CO2 test. You can pull the plugs and see if they're wet and make a decision from there.
Old 06-28-2010, 04:06 PM
SlimSvt's Avatar
SlimSvt SlimSvt is offline
Vehicle: 2004 Ram 1500
Rep:19
SlimSvt is on a distinguished road
More than likely you blew a head gasket...
Old 06-28-2010, 05:04 PM
Why do you think you have water and oil mixing ? Hows the oil look ? Does it look like a choclate milkshake ?
Old 06-28-2010, 05:45 PM
actually plugs were all dry and looked normal no oil or any residue as far as the oil and coolant mixing definitely seen it coming out when i drained the oil and along with that i noticed alot of the coolant wasent coolant it was water and coolant and i believe a lot of it was boiling off so i need to look into that. the intake gaskets were pretty much rotted out so with the new ones i think that issue will go away along with coolant.
Old 06-28-2010, 05:51 PM
If your just gonna reseal the intake , make sure you do the belly pan gasket on the bottom side of the intake . Their notorious for going bad and sucking oil out of the motor .
Old 06-28-2010, 06:22 PM
Resident Technician
Rep:1915
If the oil and coolant weren't mixed the the water/coolant you drained was probably from when you pulled the intake. When you say boiling off, where do you think it was going?
Old 06-28-2010, 08:36 PM
i did replace the gasket on the underside of the plenum it was pretty csked in oil along with the pcv hose and valve. as far as the water coolant issue i was told it was boiling off because there was too much water in the system causing it to overheat and boil it away. and i also noticed today that there was some water in the transmission pan sorry for all of the questions just wanting to clarify what is causing the symptoms.
