Old 06-28-2010, 10:36 PM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Vehicle: 2005 Dodge Ram 1500
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
Question Brake/ABS Glitch??
So im sitting at a stoplight...i hear a ding, look down both my ABS and Brake light are illuminated, what the hell? so i drive down the hill realize my speedo is not working either....so i pull over shut the truck off fire it up everything is fine brakes work, speedo works...my question is what could cause this?? don't have a scan tool at home so can't scan it!
Also thought my knobby wide tires might have swiped a speed sensor off..check both the driver and passenger side...drive side has the brake line and then an electrical wire going into the back of the rotor, connected up behind wheel well, everything looks fine! go to the passenger side all i find is a brake line? is it suppose to be like this? or is my speed sensor just gone?
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
Old 06-28-2010, 10:40 PM
Rep:1845
An intermittent fault with a speed sensor is most likely.
Old 06-28-2010, 10:46 PM
Ruffian11's Avatar
Rep:140
Ya i am going to plug it in tomorow to see what is stored!
But should there not be a speed sensor going to the passenger front wheel? there is one on the drivers side!?
Old 06-28-2010, 10:49 PM
Rep:1845
There should be one on each front wheel. If one were missing, a hard fault should be stored.
Old 06-28-2010, 11:06 PM
Ruffian11's Avatar
Rep:140
ya, and that would keep the ABS light illuminated would it not?
I got under there crawled around found no wire, connector or bracket for the wire? this struck me as odd!
Old 06-28-2010, 11:10 PM
Rep:1845
Seems like I've heard this story before but the service info says there are two up front.
Old 06-28-2010, 11:24 PM
Ruffian11's Avatar
Rep:140
Thanks for the help, when i plug in i will see what it says!
Is it possible for the other speed sensor to be on the front diff?
Old 06-29-2010, 09:27 AM
Rep:1845
No, they'd be at each hub.
Old 06-29-2010, 03:12 PM
Ruffian11's Avatar
Rep:140
I guess the only way to find out is to plug in which i am going down to do now...it would help if someone with an 05 ram could pop there head under there truck and have a peak haha!!
Old 06-30-2010, 10:02 PM
Ruffian11's Avatar
Rep:140
Plugged into the truck...no codes found at all?
So i checked out both RWD ABS and 4Wheel ABS, not sure which mine has...so how can you tell? and i went into the data stream an while stopped the rear sensor said 0 KPH but both the front ones said 55 KPH....is this one way to tell if i just have rear ABS? thanks!
