Old 06-28-2010, 09:37 PM
jester137 jester137 is offline
jester137 is on a distinguished road
Default RBZ Question
I found some RBZ radios on ebay and I want to know if 1) $350.00 is a good deal? 2) How difficult is it to upgrade from my stock RES WITHOUT UConnect? 3) What additional parts do I need to be able to use UConnect? I am going to keep looking for nav radio (Don't know what it's called) but if I do find one is there again additional hardware or does it use the sat radio antenea for GPS??
Old 07-01-2010, 04:56 PM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:71
topgun will become famous soon enough
There are 2 different RBZ radios. One with SAT radio and one without. I've seen both listed on Ebay. So be sure you are looking at the correct one. As far as UConnect, you still need to add the module just like with the RES. And the dealer has to activate it with his Star tool.
If you plan on using the RBZ as is, it is pretty much plug and play. I added a camera with mine so a trip to the dealer was needed to turn it on. As a note, the 09 did not come with a RBZ so if you have that year truck, the dealer has to use the REN code since the RBZ is not on the options list. The RBZ is the REN replacement and basically the same.
On the Nav radio, which would be a RER, you would need the GPS antenna in addition to the SAT antenna. I think it is in the $40 range and gets mounted under the dash above the radio.
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Cooper AT3 285/70/R17's, S&B Intake, Moroso Catch Can
Old 07-21-2010, 03:33 AM
FNG's Avatar
FNG FNG is offline
Vehicle: 09 1500 crew
Color: black pearl
Rep:23
FNG is on a distinguished road
I bought a RBZ radio off ebay for under $300. Got lucky, it was sold from a dealer that had replaced it on a new customers car that wanted the GPS model. I also got a lockpick and camera from another seller and hooked everything up myself. No need to involve the dealer. All works awesome and got another free year of sat radio, well still remains to be seen if it will be a full year, but its been about 4 months so far.
Old 07-21-2010, 06:58 PM
peppy peppy is offline
Vehicle: 2010 Dadge Ram 1500 Quad cab
Rep:23
peppy is on a distinguished road
I am wanting to change out my radio as well and have a couple questions for ya. i have 2010 ram with the reg cd radio. nothing fancy with it. If i upgrage to the RER or Ren would i need to change the dash bezel or are the radios the same size?. second, instead of bringing it to the dealer to get the cpu flashed cant i just buy the lock pick?
Old 07-21-2010, 07:07 PM
Rep:23
blah double post..
