Old 06-28-2010, 10:41 PM
Powrbotr Powrbotr is offline
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Powrbotr is on a distinguished road
Default Compressor electrical problem
Fan works. AC switch lites. Clutch does not activate. Bypassed the switch. Tapped into the power wire in the module containing the fuses and into a vacant space controlled by the light switch. Turn on the lights and the compressor starts. Does the module need replacing as was suggested. Any suggestions. Thanks
Old 06-29-2010, 08:18 AM
Rep:1890
You need to check the a/c charge level, high and low pressure switches, wiring and relay.
Old 06-30-2010, 12:21 PM
KSutherland KSutherland is offline
Vehicle: '02 Ram 1500 QC 5.9L
Color: Blue
KSutherland is on a distinguished road
Ditto what he said you need to check the pressure...first. Sorry to ask a question in this thread but does anyone know how ounces you should put in? and what happens if you don't put enough in?
Old 06-30-2010, 01:43 PM
Rep:1890
29 ounces. If it's low you will have less than normal cooling and possibly rapid compressor cycling.
