Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 06-29-2010, 12:08 AM
dirty97ram dirty97ram is offline
Vehicle: 97 ram 1500 ext cab short bed
Color: bedliner
dirty97ram is on a distinguished road
Question ac stops blowing at higher rpm????
i have a 97 ram 1500 with the 5.2 and the ac works fine until i give it more gas an it gets to a higher rpm is this normal or is something wrong?
Old 06-29-2010, 01:05 AM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
how high is high RPM? If you are really romping on it, I believe our trucks shut the a/c off at certain throttle positions for more power.
During normal driving, though, it should stay on. Maybe your belt is slipping?
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
Old 06-29-2010, 04:46 AM
984wdram 984wdram is offline
Vehicle: 1998 dodge ram
Color: deep amythest and silver mist
984wdram is on a distinguished road
mine does the same thing. only happens to me when i mat it or have the cruise on and start goin up a hill. i think when the motor is under a load it des it.
Old 06-29-2010, 07:26 AM
Rep:1890
It's called wide open throttle cut out. It shuts off the compressor to free up engine power.
Old 06-29-2010, 08:23 PM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Trim Level: Laramie SLT
Rep:55
Ram15002ndgen will become famous soon enough
If that isn't the cause, there is also a check valve coming off the plenum on the passenger side that can cause that problem. It's hooked up to your vacuum lines. Cheap, easy fix.
www.beatcraigslist.com - for posting dangers & secrets
Old 06-29-2010, 08:36 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
my 97 does that but it doesnt turn off it drops to like defrost LOL
Old 06-29-2010, 09:43 PM
Color: bedliner
ok thank you guys
Old 06-29-2010, 10:01 PM
Or it could be low on refrigerant . Low side switch cutting it out .
Old 07-01-2010, 04:15 PM
g2tiger's Avatar
g2tiger g2tiger is offline
Vehicle: 1994 Ram
Color: Grey and Silver
Rep:24
g2tiger is on a distinguished road
My a/c drops to defrost and floor mode when I am at highway speed and start up a long hill or bridge. It never cuts off but diverts untill my speed is back up. I think it has to do with the ammount of vacuum and throttle.
So what did we decide is the fix? The orifice check valve?
Old 07-01-2010, 04:30 PM
Rep:1890
Vacuum check valve is usually the culprit.
