Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 08-01-2010, 01:12 PM
speedy41058 speedy41058 is offline
speedy41058 is on a distinguished road
there are two check valves to change. one is located on passenger side of the manifold and the other is off the fire wall. try changing them out and that should work.
Old 08-04-2010, 09:57 PM
hunTer06's Avatar
hunTer06 hunTer06 is offline
Vehicle: 2011 Dodge Ram
Trim Level: Outdoorsman
Rep:60
hunTer06 is on a distinguished road
Send a message via MSN to hunTer06
The same thing happened to my truck and this fixed it....
While washing the truck one day I noticed a hose off of one of those "canisters" under one side of the bed. (sitting along the frame) I popped the hose back on, and that fixed the A/C problem.
Not saying that is what is wrong with yours, but maybe you have a vacuum leak somewhere
Old 09-08-2010, 02:50 AM
tekstrand24's Avatar
tekstrand24 tekstrand24 is offline
Vehicle: 1997 Dodge Ram
Trim Level: 1500
Color: Chestnut Brown
Rep:57
tekstrand24 will become famous soon enough
Mine does that every time after I get it serviced at the dealer. Because my truck is lifted when they put it on the lifts it pulls my vacuum line off and they are to dumb to recheck it so I just have to put it back on when I get it back.
Old 10-04-2010, 03:37 PM
xlstreetglide xlstreetglide is offline
Trim Level: SLE
Color: Grey
xlstreetglide is on a distinguished road
Pics please
Old 10-21-2010, 12:12 AM
mrsamtz mrsamtz is offline
Vehicle: 2000 Dodge Ram
Color: Garnet Red w/Gold
mrsamtz is on a distinguished road
actuator on transfer case (4x4) was the remedy on mine....check valve replacement did nothing.......
Old 10-27-2010, 06:15 PM
Dtimekw Dtimekw is offline
Vehicle: 2001 Ram
Color: Blue
Rep:23
Dtimekw is on a distinguished road
Sounds like a vac leak for sure. All of these could be the culprit. If you can't find the leak, put a check valve on the vac line itself where it goes into the firewall. Assuming yours is the same as my 01 1500 with 5.9, its the vac line that goes thru the firewall along with the A/C lines. There is another one above that which goes into the cowl area. If this fixes the problem then you either had a vac leak or bad orig check valve. If you replaced the orig check valves, keep looking for the vac leak but at least now your vent problem is working. BTW, make sure you put the check valve on the correct way. Generics from Autozone etc.. can go on backwards so take note and let us know what happens.
01 Ram Sport, 5.9, Body/Suspension lift on 36's, 4wd
Old 03-31-2014, 11:49 AM
it indeed was the vacuum/check valve on the transfer case......
Old 04-08-2014, 09:11 AM
cj5orion's Avatar
cj5orion cj5orion is offline
Vehicle: '98 ram 1500,mag,4-whl,lifted
Color: green
cj5orion is on a distinguished road
OK,,,so can I get 3 check valves, all the same,and replace ?
2 under the hood.1 on transfer case
do the "autozone boys" know the right ones or should I remove old n take em in ?
where might this transfer case valve be ?
pass side ? drivers ?
VERY irritating lil prob ! NEEDS to get fixed
I know its a pain,,,but pics would be great !
'98 ram 1500,skyjacker lift,BFG Mudders,Magnaflow exhaust
aaaaaand 1 choc lab----bird dog !
Old 04-10-2014, 01:25 PM
jssmith76's Avatar
jssmith76 jssmith76 is offline
Vehicle: 2009 Dodge Ram 1500
Color: Sunburst Orange
Rep:26
jssmith76 is on a distinguished road
Send a message via MSN to jssmith76 Send a message via Yahoo to jssmith76
Any new info on this and/or pics? I'm having this problem on my '97 and sure would like to be able to see pictures of what I am supposed to be looking at.
Thanks,
Josh
Thanks,
Josh
2009 Ram 1500 Sport 4x2 Quad Cab, Sunburst Orange - Bone Stock
