Old 06-29-2010, 04:38 PM
BBAUM's Avatar
BBAUM BBAUM is offline
Vehicle: 2003 Dodge Ram 1500
Trim Level: Hemi 5.7l
Rep:21
BBAUM is on a distinguished road
Default Bully dog gt!!!
hey i jus got my new bully dog gt! but idk what key on power fuse is i need help! which fuse can i use for the tuner..
Old 06-29-2010, 09:24 PM
gtfloyd's Avatar
gtfloyd gtfloyd is offline
Vehicle: 2008 Ram 2500 4X4
Color: WHITE
Rep:21
gtfloyd is on a distinguished road
I just bought mine last thursday, I used the cigarette lighter, fuse #40. It is controlled by rolling the key to on. This was recommended by the manufacturer, originally I had it plugged in so it would never turn off automatically. I found its much more convenient to have it cycle with the truck than use the switch. I hope this helps.
What doesn't kill us only makes us stronger, unless we end up comatose. In which case we slowly degenerate into a shell of what we used to be.
Old 07-03-2010, 04:33 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
how much u spend i return that for a superchip
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 07-04-2010, 01:50 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
what research did you guys do before you bought the bully dogs? believed in the marketing hype? didn't ask experienced users on the fast trucks here what they got?
Old 07-05-2010, 01:01 AM
Trim Level: st
Color: silver
Rep:68
ya man alwys ask and look on forums about stuff before you buy it just my input
Old 07-05-2010, 01:16 AM
Oh sure...anything you read on the intarwebz is true... Good luck with the tuner and give us some feedback on how it works out for ya!
Old 07-05-2010, 08:27 PM
gtfloyd's Avatar
Color: WHITE
Rep:21
I am currently running the 87 octane tune and its noticeably smoother between shifts and the acceleration is a lot better. Fuel economy is about as measly as before, but the power difference is noticeable. I like the ability to monitor 13 different things from a single device. but I'm a nerd like that I guess.
Old 07-06-2010, 06:14 AM
Trim Level: st
Color: silver
Rep:68
lol if you dont mind how much you spend on it like 300
Old 07-06-2010, 09:59 AM
chefred112's Avatar
Rep:656
try monitoring this stuff..this info is what I can monitor with my diablo while driving and also what the tuners use for when they custom tune..
there are more available pids to monitor but these are the necessary ones to tune off of..
ACT (F) or IAT
ECT (F)
OPEN LOOP FA (AFR)
RPM
MPH
1/1 Long Term ADAP(%)
1/1 Short Term ADAP(%)
2/1Long Term ADAP (%)
2/1 Short Term ADAP(%)
Baro (PSI)
PRATIO (PRatio)
AVG Total Working PW (us)
KNK Sensor 1 (V)
KNK Sensor 2 (V)
KNK TOTAL RETARD (DEG)
MAP TO USE (psi)
RAW TPS 1 (V)
RAW TPS 2 (V)
ACTUAL SPARK CYL 1 (DEG)
ACTUAL SPARK CYL 2 (DEG)
ACTUAL SPARK CYL 3 (DEG)
ACTUAL SPARK CYL 4 (DEG)
ACTUAL SPARK CYL 5 (DEG)
ACTUAL SPARK CYL 6 (DEG)
ACTUAL SPARK CYL 7 (DEG)
ACTUAL SPARK CYL 8 (DEG)
BASE SPK (DEG)
THROTTLE BLADE POSITION (%)
Old 07-06-2010, 06:10 PM
gtfloyd's Avatar
Color: WHITE
Rep:21
ACT (F) or IAT
ECT (F)
OPEN LOOP FA (AFR)
RPM
MPH
Baro (PSI)
PRATIO (PRatio)
KNK Sensor 1 (V)
KNK Sensor 2 (V)
MAP TO USE (psi)
RAW TPS 1 (V)
RAW TPS 2 (V)
BASE SPK (DEG)
I'm guessing thats the trinity? I spent $400 on the unit and installed it myself. "install" is a little over the top, I plugged it in and ran a power wire. Anyway, if your comparing the trinity to a GT, its a $1k unit v $400. A comparable BD product is the PMT. So...apples and oranges in my opinion. Broke ass me cant afford to spend that kind of money.
