Old 06-29-2010, 06:07 PM
SPEEDFREAK's Avatar
SPEEDFREAK SPEEDFREAK is offline
Vehicle: 2010 RAM R/T
Trim Level: 450HP & 450TQ
Color: SPEED WHITE
Rep:180
SPEEDFREAK has a spectacular aura aboutSPEEDFREAK has a spectacular aura about
Default 2010 ram hemi hp# 440 modded, x pipe or h ?
I have modded the motor, and now i need info on which is best for the hemi motor. Putting out this much hp i would think i need to install a x or h pipe. Which one and why? Our motor is in the 09 10 callanger rt, they are putting down about 370 hp while iam putting 352 down i think if i put the x or h pipe it will help balance the motor. I was wondering about the tq. There # are higher also than mine iam putting 360tq there putting down 380 tq.
The challangers ive been checking on have about the same mods. So it moves me to think if i add the x pipe i can pick up more hp and tq. The only thing else to figure before, is how much hp and tq i am lossing by having these stock tires at 33" high, the challanger rt tires are 28 29" high. How do i figure how much more hp and tq i would have if i put 30" high tires on. I my be putting out more power now and i dont even know it. It my be best to keep the exhaust going in to the 3" pipe. But the srt is dule. Those cars weight is around 4200lbs my truck is 4700. There has to be a point were faster rpms and shifting, higher hp crosses tq to be better at what point? When? Am i there? When do i put dule 3" piping vs
2 1/2".
k&N CAI, 3 1/2" 90 on CAI at TB, 85mm BBK TB,denso sp,180stat,syn oileng & rear gr,Catchcan, Addco sway bars f&r
1 3/4"amer rac hders high flowcats, 2 1/2" H pipe dul 2 1/2" piping, Diablo CT, Bilstin, Mcdrop 2/4,1deg cam 295/45-20bfgkdw,efan,13.4gtech
Old 06-29-2010, 06:13 PM
Rep:1890
Is the Challenger an RT or SRT-8? There's a big difference in the two. You're not losing torque because of tire size. The engine is going to make the same torque regardless of tire size. A list of the mods you currently have done would help.
Old 06-29-2010, 06:20 PM
SPEEDFREAK's Avatar
Color: SPEED WHITE
Rep:180
Default Mod list ram rt
It a challanger rt not srt iam compareing.
Kan intake, bbk throttle body, amer racing headers, y pipe, 14" magnaflow muffler. Complete custem diablo tune. Syn oil, catch can, syn in rear gear. The dyno guy said he picked up more hp and tq when the customer put smaller diam tires on his car. Dynod back to back.
Old 06-29-2010, 06:45 PM
I push the skinny pedal
Rep:3277
The reason you're seeing a gain in hp/tq is because of the rotating inertia, a smaller tire has less mass to turn, so you put more down to the dyno, rather than lose it to overcoming the static inertia. Also, your gear ratio may be better suited to a smaller diameter tire.
Now, if you have the room to run an x-pipe you'll get smoother flow through the pipes, but if you won't be able to get the pipes together then an H-pipe works just fine. When it comes to trucks, the x-pipe is not always practical, so I'd be looking at the H-pipe to balance the bank pressures and increase the scavenging effect.
As for 2.5" vs 3" duals... if you're planning on blowing the engine (SC or TC) then 3" duals would make sense, but if you're planning on staying NA, then you'd lose too much exhaust velocity and would begine to stagnate the flow in the pipes with a 3" dual as there's just not enough velocity to keep the optimal flow. One way around this is with the use of cutouts, run your current exhaust, but run cutouts to get it out asap, normally right before the y-pipe.
Kurtis
Old 06-29-2010, 06:54 PM
doz doz is offline
Vehicle: 2014 Dodge Ram Crew Cab 4x4
Rep:76
doz will become famous soon enough
Also, what about the tranny? You may lose a little more due to the transmission being different. Really hard to say. I really dont think an X/H pipe will help you THAT much, not enough to bump up 15-20 hp.
DS Trinity w/ custom tune, S&B Intake, ARH LT Headers, Magnaflow Cat-back, 87mm PTB, BT Catch Can, 180* T-Stat, v6 E-Fan, 5000k RS HID, XD Misfits w/ 35"x12.5"x18", Rancho QL level, 5% tint w/ 35% full windshield, Hifonics Brutus 1100.1 w/ Sundown SA12 in ported FoxBox
Old 06-29-2010, 07:43 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
You'll see some benefits from going down to a 30" tire b/c your final drive ratio changes. I wouldn't mess with the exhaust anymore unless you do more motor mods.
My vote for your next mod is torque converter.
Old 06-29-2010, 08:11 PM
ScatPak07's Avatar
Rep:970
You are saying that the stock Ram tires are 33" tall? I am pretty sure they are 30" or 29" from the factory. The smaller diameter tire just allows more rotations, like Cdnoil said.
Old 06-29-2010, 08:50 PM
MotorCityRam's Avatar
MotorCityRam MotorCityRam is offline
Vehicle: 2010 Ram QC 4x2
Color: Inferno Red
Rep:23
MotorCityRam is on a distinguished road
The 275/60/20s are 33" tall.
I think you're at a level where the exhaust should be addressed. Dumping into a section of single pipe isn't bad but the 3" is too small IMO. It doesn't support the cross-section of dual 2.5" pipes funneling into it. Should be 3.5" minimum. You're probably at that point that dual 2.5" is adequate. 3" isn't going to hurt you though IMO. Could always test by pulling the Y pipe on the dyno and run the headers open.
You don't want any back pressure past the header collectors. All your scavenging is done from the collector forward. The rest should be as free flowing as possible.
Sean M
2010 Quad Cap Sport 4x2 / Inferno Red / HEMI / 3.92s / leather / Truxedo Truxsport tonneau
Old 06-30-2010, 12:28 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
that's why i run an almost true dual setup, 3" from the collectors all the way to muffler which is 3" dual in/ 3.5" single out
Old 07-01-2010, 09:05 AM
SPEEDFREAK's Avatar
Color: SPEED WHITE
Rep:180
Default ram exhaust mods
first off thank you for info. iam going to continue the 2 1/2" exhaust from the headers all the way back with an h pipe true dulls. now one muffler with dull in and dull out or two separt mufflers or maybe just use 4 reonators. iam doing the tires.
