Old 07-01-2010, 10:16 AM
MotorCityRam's Avatar
MotorCityRam MotorCityRam is offline
Vehicle: 2010 Ram QC 4x2
Color: Inferno Red
Rep:23
MotorCityRam is on a distinguished road
I think you'll likely leave some power on the table with that setup. An X with true duals maybe since it'll balance better and give each bank access to the entire system. With an H...I'd go to 3".
I'd do two rectangular mufflers turned upright next to each other. Only DIDO I can think of worth trying would be that Magnaflow piece that's an X crossover inside the muffler itself. Two birds w/ one stone there.
Sean M
2010 Quad Cap Sport 4x2 / Inferno Red / HEMI / 3.92s / leather / Truxedo Truxsport tonneau
Old 07-01-2010, 11:46 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
..I would tend to agree with Sean..
Old 07-01-2010, 01:17 PM
USC Ram's Avatar
USC Ram USC Ram is offline
Rep:31
USC Ram is on a distinguished road
just realize that without lowering it, the truck is going to look a little silly with tires significantly smaller then the stock 33"s. If youre absolutely just looking for every last lit bit of speed, thats one thing, nut if its your daily driver, it might not look as good IMO.
I'd rather push my Dodge then drive a Chevy
Old 07-01-2010, 01:51 PM
Color: Inferno Red
Rep:23
Completely agree on the tires. that's a big wheel opening to leave unfilled.And if the weight doesn't change much you could see the number drop. A swap to numerically higher gears can skew the rwhp numbers down. A local Ford shop that started offering Mercury Marauder pkg's that included 4.10's starting doing the dyno runs after speed part installation but BEFORE the gear install because some owners were whining about the numbers, even though the cars were noticably quicker.
Sean M
Old 07-01-2010, 10:38 PM
SPEEDFREAK's Avatar
SPEEDFREAK SPEEDFREAK is offline
Vehicle: 2010 RAM R/T
Trim Level: 450HP & 450TQ
Color: SPEED WHITE
Rep:180
SPEEDFREAK has a spectacular aura aboutSPEEDFREAK has a spectacular aura about
Default ram rt exhaust
once agine thank you. i just enjoy knowing i can come home after a hard days work and gather info on my truck from the like. ok ill do the x pipe but cant do the muffler one since the x needs to be at the end of my headers and dull mufflers got it. when i buy the tires iam getting the mc drop 2,4. perfect. now i know what to do. thanks
k&N CAI, 3 1/2" 90 on CAI at TB, 85mm BBK TB,denso sp,180stat,syn oileng & rear gr,Catchcan, Addco sway bars f&r
1 3/4"amer rac hders high flowcats, 2 1/2" H pipe dul 2 1/2" piping, Diablo CT, Bilstin, Mcdrop 2/4,1deg cam 295/45-20bfgkdw,efan,13.4gtech
Old 07-02-2010, 08:24 AM
kickgas's Avatar
kickgas kickgas is offline
Vehicle: 2005 Ram QC
Trim Level: Hemi Sport
kickgas is on a distinguished road
I currently have true 2.5 inch duals with a X pipe and 2 Flowmaster 40's. It was good until I put in the X pipe. Now power doesn't come on until around 3400 RPM. Torque went away. I found out that the H pipe promotes torque, the X mid-top end power. I tow a 27 ft trailer, and the Hemi isn't too happy right now. I'm switching to the H pipe as soon as I get some down time.
Also, the A/F is off now through the power band. Running rich now, lots of black in the tailpipes. Not sure if a tuner would correct or not. I'll try to post up some pics from the laptop.
Bud
05 Hemi Sport, Air Raid intake, true dual exhaust 2.5" Magnaflows
Old 07-02-2010, 08:53 AM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
After having a lightning for years now, my thought is use the magnaflow with the built in X, leave it 2 1/2 and call it a day, however you are running true duals. I was making well into the 400hp range and had 540ftlb of torque with that set-up. I deleted the cats, put LT headers on and lost torque, down to 535. Most stock exhaust can handle almost 500hp and high torque ranges from what I have learned. It's a tweaking game at best with your programmer, to pull out the powa!
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
Old 07-02-2010, 08:58 AM
Color: Inferno Red
Rep:23
Well....there's a good example of theory not always proving out in real use. There is the difference that the newer truck is cammed differently (and has the VCT) so YMMV. The system should be as free flowing as possible but when the combination is cammed to take advantage of a particular exhaust system, there can be low-end losses like that.
My suggestion would be to welcome that and use it as an excuse to gear the thing up a bit.
Hate that these are speed density setups. That a/f problem wouldn't be there w/ a MAF setup.
Sean M
Old 07-02-2010, 09:05 AM
BLKSVT's Avatar
Rep:222
I agree totally.....
Old 07-02-2010, 09:38 AM
chefred112's Avatar
Rep:656
Bud
do you have a programmer (preferably superchips or diablo), datalog fuel trims to see how rich your are running...do you have full details of all your mods?
