Old 07-10-2010, 01:51 PM
simply2cool's Avatar
simply2cool simply2cool is offline
Vehicle: 2007 Dodge Ram 1500
Trim Level: Quad Cab SLT BigHorn
Color: Brilliant Black Pearl
Rep:44
simply2cool is on a distinguished road
Did you see this thread on how to remove the head unit.
http://www.ramforumz.com/showthread.php?t=45620
2007 Ram 1500 Quad Cab, SLT Big Horn, 4.7 Flex Fuel, Volant CAI, Hypertech Max Energy, Westin Nerf Bars, MYGIG upgrade.
Old 07-15-2010, 10:58 PM
Wader999 Wader999 is offline
Wader999 is on a distinguished road
I put in a PAC AOEM-CHR3 and added a amp for a sub. I get more than enough bass. I will have to check out how much it looses as I turn it up. It was easy to install, and when I do replace the head unit, it will be easy.
Actually all the access to the stereo components are easy to get to and work on.
Old 08-15-2010, 07:10 AM
drag737 drag737 is offline
drag737 is on a distinguished road
Dont u need some kind of converter or something to make it work with CANBUS?
Old 08-15-2010, 12:30 PM
chrisisbored24 chrisisbored24 is offline
chrisisbored24 is on a distinguished road
ok so update, turns out theres only 2 screws holding the center of the dash on the 2010 1500 located UNDER the little rubber mat thing in the top tray where it says dodge, then a little gentle pressure and that whole center console pops right out.
as suspected no preouts on the factory deck so i started lookin at aftermarket and found out 2 important things
1) yes you do need a canbus module for the install (150$)
and
2) no you cant use the factory satellite radio with an aftermarket hu (so another 150ish $)
this info kinda wrecked my day when i heard it lol
tho im sure i can get both those units online for less (my only real concern is getting the right canbus so if anyone knows a part number/model that will work with the '10 1500 ram lemme know)
Old 08-15-2010, 02:20 PM
RammD RammD is offline
Vehicle: 2010 RAM SLT REG. CABX2
Color: CRYSTAL BLACK PEARL
Rep:61
RammD will become famous soon enough
Chris,
I think the pac adaptor you would need is the CHA07, and you can get it for about $75, not $150.
http://www.discountcarstereo.com/detail.aspx?ID=1242
As far as the Sirius Radio....you're gonna need a kit for that to allow the functions of Sirius to work with the new H/U. But do searches on the actual SKu's..you should be able to get it for less then $150. Check amazon and even ebay. Good luck man.
Old 08-15-2010, 03:33 PM
no no the canbus module to install a new HU is what i was told was 150$ which includes a wiring harness
the part u posted looks like its to hook up an amp to the existing factory unit,
about the sat receiver im pretty sure ive seen refurb units online for like 75$
