Old 06-30-2010, 03:20 AM
gtfloyd's Avatar
gtfloyd gtfloyd is offline
Vehicle: 2008 Ram 2500 4X4
Color: WHITE
Rep:21
gtfloyd is on a distinguished road
Default tuner v. warranty
I recently bought a Bully Dog GT and I am about to get an oil change so I put the comp back to stock and removed all the components from the truck. My thinking is, as long as the truck doesn't break at some unusually low mileage, I should be fine as far as the lifetime warranty work is concerned. I did some research and I've found that a dealer ISNT obligated to honor the warranty that Chrysler LLC has given you. SO, since I've already modded the exhaust(cat back Gibson Super Truck) and put a CAI(K&N 63S) I figured that it was more than enough "mods" to make a dealer show me the door. I have a pretty good relationship going with my dealer here in OK, I have had all service done here except 3 oil changes. I know that a dealer can find proof of programmer or tuner use EVEN if it is a diablo sport, so they can screw you no matter what. All that to ask, will a dealer check your onboard comp if your rear end goes out just over 100k(which 2 of mine have) and an engine has more than 200k mi and needs some rebuilding work? Both seem like respectable numbers, even if you get them serviced normally. I apologize for the rambling but this legal jargin I've been reading has me a little concerned.
What doesn't kill us only makes us stronger, unless we end up comatose. In which case we slowly degenerate into a shell of what we used to be.
Old 06-30-2010, 06:55 AM
UltraFlame's Avatar
Vehicle: 2007 Dodge Ram Quad
Rep:840
The dealer would have to proove the mod you did to your vehicle caused the mechanical failure. This is all covered by a Magnussen Moss Act.
Old 06-30-2010, 08:30 AM
Rep:1909
Let's not get too carried away with this. A tuner instantly voids the engine warranty, regardless of what the Magnusson-Moss act says. Most dealers will allow the CAI and exhaust slide though because the possibility of them causing any real problems is small.
Old 06-30-2010, 10:03 AM
I push the skinny pedal
Rep:3277
As a rule of thumb, taking the computer's programming out of the factory specs WILL void the warranty... now... if you get a good programmer that stores the factory tune AND leaves no footprint behind, then you have a chance, as you can just load the stock tune in before taking it in for service.
Kurtis
Old 06-30-2010, 01:50 PM
volcom54626's Avatar
volcom54626 volcom54626 is offline
Vehicle: 2006 Dodge ram QC
Color: Brilliant Crystal Black
Rep:17
volcom54626 is on a distinguished road
What you MAY want to do if your really concerned about it, is read your warranty contract, legally the warranty information has to be disclosed, what that means is they(Chrysler corporation, or the dealer) has to have their warranty information written out and provided to you the consumer, with a list of what is going to be covered and what is not going to be covered. Basically they have to state that modifying your engine an anyway, or specific ways (I.e. a tuner, cold air intake, supercharger,ect) will void the warranty.
With that being said, I have not given you any legal advice, or have instructed you in any legal way, this was simply informative.
Old 07-05-2010, 12:37 AM
gtfloyd's Avatar
Color: WHITE
Rep:21
Well they have yet to plug in my OBDII adapter into their computer and I've taken it in for service at least 13 times. what are the chances they actually check it? I have a friend who ran a tuner on a f-150, broke the tranny @ 15k. He took it in without a tune on it and ford replaced it. I have never had a real problem and I dont want to mess myself up but if they dont check it I really dont see the harm. Any thoughts?
Old 07-05-2010, 01:00 AM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
x2 what everyone said lol but they cant see if do your oil yourself
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 07-05-2010, 01:07 AM
gtfloyd's Avatar
Color: WHITE
Rep:21
I read your replies more carefully, you said it voids the engine warranty...what about the tranny, transfer case, rear end? Is the rest of the power train ok? I am not too worried about the engine
Old 07-05-2010, 01:20 AM
Given enough time, the manufacturer can come up with a case that a modification that increases HP or torque beyond their spec can contribute to any powertrain component failure.
But understand that their designs are conservative. For instance, it's a known fact that the transmission in my SRT8 can handle 500 HP and 500 lb of torque. The rear differential can't take much more than that.
But the engine only puts out 425/430 at the crank stock. They do leave ya some room to play with. A tuner is not going to give you huge increases in either value.
PimpJuice's Avatar
PimpJuice PimpJuice is offline
Vehicle: 2007 Dodge Ram 1500
Color: Blue
Rep:150
PimpJuice has a spectacular aura aboutPimpJuice has a spectacular aura about
Would headers and a cam also void the warranty?
Also to clarify, my warranty is an extended warranty, i got it and the truck from a chevy dealership.
dealer, life time, lifetime, warranty
