Old 06-30-2010, 09:35 AM
HOTHEAD's Avatar
HOTHEAD HOTHEAD is offline
Vehicle: 2009 1500 Quad SLT
Color: Black on Black
HOTHEAD is on a distinguished road
Default Trailer Hitch question
I did a search, so if this has been asked before, please forgive me.
When I purchased my truck,(1500 quad cab) it only came with the towing "prep" package. I have the 4 & 7 pin connectors molded into the truck, and it looks like the hitch is complete up under the frame, as if I wanted to install a ball directly onto the bumper. However there is no actual female reciever coming out the rear of the truck.
In doing some reading this morning, If I am correct, there is another piece that needs to be installed if I want to put on a drop hitch.
Is anyone familiar with these? I did look around, and am waiting on calling the dealer ( not open yet) but I think I came across one on ebay. Its not OEM, so I was wondering about difficulty of installation, and if the ratings were comprable to what the dealer would put on.
As always, Thank you for any help
Regards
HOTHEAD
http://cgi.ebay.com/ebaymotors/Curt-...Q5fAccessories
Old 06-30-2010, 09:40 AM
Rep:1909
They aren't bad to install but I see the one you've linked to doesn't seem to include the mounting hardware, plastic cap or pull wire for the bolts, which is a MUST HAVE for installation. I'd make sure it come with all of the above before spending any money.
Old 06-30-2010, 09:43 AM
HOTHEAD's Avatar
I understand the mounting hardware, but what is the "pull wire" and plastic cap? If you dont mind me asking. & thanks
Old 06-30-2010, 09:45 AM
Rep:1909
The plastic cap covers the bolt that will run through the hole in the bumper. The pull wire is made to thread around the bolts that must be installed through the inside of the hitch.
Old 06-30-2010, 09:53 AM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3934
Hey HOTHEAD, it may be helpful if you went back and filled out your User CP, it would help us help you by knowing what you have!
Old 06-30-2010, 10:36 AM
HOTHEAD's Avatar
Sorry, Done
Old 06-30-2010, 11:38 AM
Magnus Magnus is offline
Vehicle: 2010 Ram 1500
Color: Orange
Magnus is on a distinguished road
The product you linked too looks as if it is only the reciever, which would need to be attached to a crossmember that spans the frame rails. Is that cross member already installed? Here is a photo of what I know as a full class III\IV receiver.
Old 06-30-2010, 11:55 AM
HOTHEAD's Avatar
Yea, it looks like the cross member is already up under the truck. I actually have found a Youtube video on the install, now I am researching the load capasity of the aftermarket ones vs the OEM. The dealer wants $145 for the part, however I am finding them on ebay for around the $90 range.
They do come with the "pull wire" but no plastic cap. There is a cap in my bumper now, but the way the video of the install looks, the new 3/4 nut does not sit flush after install so I think I need a different cap.
Thanks for all the help so far
Regards
HOTHEAD
Old 06-30-2010, 12:00 PM
Rep:1909
No, it doesn't sit flush. I believe the OEM should be class IV.
Old 06-30-2010, 01:32 PM
Color: Orange
Class III hitch is rate up to 5,000 lbs and 500 lbs tongue while a class IV is rated up to 12,000 lbs and 1,200 lbs tongue. The max rating may vary a bit depending on the manufacture. I know my '10 came with a class IV but I don't know about the '09.
