Old 06-30-2010, 07:52 PM
NuclearRam's Avatar
NuclearRam NuclearRam is offline
Vehicle: 2001 Ram 1500
Trim Level: Laramie SLT Quad Cab
Rep:20
NuclearRam is on a distinguished road
Default Smell of gas, depleted gas mileage (and I don't think it's the air filter)
Title pretty much summed it up, but here's the details.
After replacing the air filter after four hundred miles ago (she's at 96,2XX right now), I started noticing the smell of gas in the cab and a loss in gas mileage. First problem turned out to be the air filter housing (which had come loose after some rough play that weekend), but I keep noticing it even after I fixed the air filter problem.
Is there anything else that could be causing these problems?
Old 06-30-2010, 08:28 PM
eltoro2's Avatar
eltoro2 eltoro2 is offline
Vehicle: 2oo9 standard cab 4~4 1500 ram
Trim Level: plain
Color: pearl black
eltoro2 is on a distinguished road
I smell gas every now and again in my 09 . I am thinking it ha something to do with the mds system , I smell it when starting in morrings. i think the tr starts in the 4 cyl mode cause the exhust sounds funny like its only half running . dealer says nothing s wrong yep tipical .
Old 06-30-2010, 08:33 PM
Rep:4072
Does it happen after you fill up or do you notice it all the time?
Old 06-30-2010, 09:52 PM
Rep:1885
Start with the obvious and check the fuel lines and fittings for leaks.
Old 07-01-2010, 12:26 AM
NuclearRam's Avatar
Rep:20
It's a fairly frequent thing. Most obvious after just filling up though.
Gotcha. I'll take a look tomorrow morning.
Old 07-01-2010, 12:35 AM
Rep:4072
Reason I asked is I had a similar problem just after I bought my truck. It only happened just after I filled up, so I mentioned it to the dealer at my next service. They did replace the air filter, but (and I'm sure Randy can explain it better) something was blocking one of the lines allowing the vapors to be noticeable in the cab. They cleaned it out and problem gone.
Old 07-02-2010, 07:24 PM
NuclearRam's Avatar
Rep:20
Turns out...none of the above.
The smell of gas turned out simply to be some power steering fluid that had spilled on the floor...and the perception of bad gas mileage was just me getting used to city MPG again after 1000 highway miles.
Don't I feel silly
Appreciate all the help though!
Old 07-02-2010, 07:26 PM
Rep:1885
Good to know you don't have a fuel leak that could have led to a fire.
Old 07-02-2010, 07:37 PM
NuclearRam's Avatar
Rep:20
Yeah, definitely a good thing. Just have to keep all my various fluids in a better place now.
