tonneaucovered.com
Old 07-01-2010, 03:10 PM
gtfloyd's Avatar
gtfloyd gtfloyd is offline
Vehicle: 2008 Ram 2500 4X4
Color: WHITE
Rep:21
gtfloyd is on a distinguished road
Default Tire size?
From all the reading I've done it seems like the 2500s sit higher stock than the 1/2 tons. Right now I have a 3/4 ton with a leveling kit and 3" body lift and I am taller than a 1/2 ton with an 8" lift. So my question is, what would be the max size tire I could put on without compromising the travel? Im running 285/65/18 atm and Im thinking about 325/70/18 b/c its the largest firestone destination m/t available. Im getting about 50k out of the set I have now and I dont really wanna mess with success. I don't have the money for toyos and nitto m/t isnt my thing. All flash and no real purpose if you ask me. Any ideas/suggestions?
What doesn't kill us only makes us stronger, unless we end up comatose. In which case we slowly degenerate into a shell of what we used to be.
Old 07-02-2010, 01:59 PM
Lil Black 4x4 Hemi's Avatar
Lil Black 4x4 Hemi Lil Black 4x4 Hemi is offline
Vehicle: 2016 Power Wagon
Color: Blue Streak
Rep:93
Lil Black 4x4 Hemi will become famous soon enough
Send a message via AIM to Lil Black 4x4 Hemi Send a message via Yahoo to Lil Black 4x4 Hemi
Slightly OT, but the Nitto Trail Grappler isn't al flash like a Mud Grappler. It's more of an old school redesign that works REALLY well IMO.
That said my half ton has a leveling kit and Monroe load levelers. The load levelers gave it a rake....again, but I like the height. Anyhow.....I'm running 295/65/20s ( I read that the Nittos run tall so my overall height was 35.5) with no problems on factory wheels, so surely SURELY you could make the 325s work.
Luke
Partial De-Badge (doors and tailgate) Challenger Badges, Iron Cross HD Steps, Sterling Equipment Rollbar with 5 HIDs
My SLT may be gone, but it's not forgotten!
Old 07-02-2010, 02:06 PM
I agree. A 325 should work just fine. My only concern going to the wider section width and taller tire is whether or not you'd rub on the inside of the wheel well or at the trailing edge of the front bumper.
I suggest you go out and measure clearance between the tire and the fender (front and rear) and space between the tire and inner wheel well liner/suspension ball joint with the wheel pointing straight ahead. Then, turn the wheel to full steering lock and take the same measurements.
Then determine what the difference is in height between the 65 & 70 series tires to see if you still have room.
Lastly, determine the difference in section width between the 285's and a 325 to see if you have room for the additional width without having to change wheels or offsets.
Old 07-05-2010, 12:32 AM
gtfloyd's Avatar
Color: WHITE
Rep:21
I have a road armor bumper and it seems that I wont have a problem with turning. Now I'm just worried about the travel. I think I'm gonna go with the 325's. I have over 30k on my firestone destinations. I was hoping that they would die before then but I guess high mileage isnt a bad thing.
Old 07-05-2010, 09:48 AM
DaveDees's Avatar
DaveDees DaveDees is offline
Vehicle: 2010 Jeep Patriot
Trim Level: Latitude
Rep:40
DaveDees is on a distinguished road
Here's a chart with a before and after just for the tires.
from the online tire size calculator
All articles that coruscate with resplendence are not truly auriferous.
Old 07-05-2010, 12:04 PM
SUL7ENAZ's Avatar
SUL7ENAZ SUL7ENAZ is offline
Vehicle: 1999 Dodge Ram 1500 QuadCab
Color: blue
Rep:463
SUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of light
You should be able to clear those 325's and it will look great.
SUL73NAZ
Old 07-05-2010, 08:30 PM
gtfloyd's Avatar
Color: WHITE
Rep:21
that is really helpful. somehow I figured a 325/70 ended up being ~34.9/12.7. This make a lot of difference. thanks for the posts guys
Old 07-05-2010, 08:40 PM
gtfloyd's Avatar
Color: WHITE
Rep:21
what tire should I go with? I said that I didnt want to mess with success but I'm up for any new ideas...thoughts dick cepek, maxxis, pro comp, etc?
Old 07-06-2010, 12:33 PM
SUL7ENAZ's Avatar
Color: blue
Rep:463
I really like nitto's and toyos. The pro comp tires are very nice especially the extreme a/t. General grapplers and cooper zeon ltz's aren't too bad either. Make sure you get the applicable d or e rating depending on how much you tow and stay away from passanger car load ratings intended for crossover suvs. I know i probably didn't narrow it down much since i offered so many choices but if it comes down to it go by price. All of them are great quality.
SUL73NAZ
Old 07-06-2010, 06:12 PM
gtfloyd's Avatar
Color: WHITE
Rep:21
I'm sticking with E tires, I dont pull heavy often but I would rather not have another set of tires to pull a trailer.
2500, 3/4 ton, lift, tire, tires
