Old 01-08-2011, 12:57 AM
hawk5124 hawk5124 is offline
Vehicle: 2006 Dodge Ram quad cab diesel
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
hawk5124 is on a distinguished road
Hi guy's,
New to this forum stuff. I was hoping someone could help me. I have a 2006 quad cab 2500 diesel 4x4. I want to put bigger tires on it cuz the stock 265/70/17 look like tricycle tires on it. I was told I could go with 33's without lifting it. I want to get Nitto trail grappler 295/70/17 which are 33.3high and 11.6wide. The problem is I cant seem to get a definitive answer as to what kind of offset i need in the wheels. Can anybody tell me weather I need a positive or negative offset and how much of one I need to avoid any issues like rubbuing or hitting the control arm or inner fender?
Old 03-21-2011, 02:29 AM
gtfloyd's Avatar
gtfloyd gtfloyd is offline
Vehicle: 2008 Ram 2500 4X4
Color: WHITE
Rep:21
gtfloyd is on a distinguished road
Its kind of a dead thread but I bought my Nitto Terra Grappler 295/70R18s and they look awesome. They have a 4k lbs rating load per tire so I kept everything I wanted and ended up with a taller and QUIETER tire. I got over 43k miles with those destinations so I was really impressed. Especially since I only rotated them a total of 4 times(They started to cup within the first 2 months I had the truck so I gave up). Anyway, I would recommend these tires to anyone. I have yet to try it in sloppy mud but they are very capable in the OK dirt.
What doesn't kill us only makes us stronger, unless we end up comatose. In which case we slowly degenerate into a shell of what we used to be.
Old 03-21-2011, 03:22 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Originally Posted by hawk5124 View Post
Hi guy's,
You should be fine with those tires on a stock wheel actually. I had 35x12.5x17s on a stock wheel and stock suspension but because of the width of the tire they rubbed on the control arm at full turn (not much)
I have 1.75" wheel adapters now and because of the added width they rubbed on the lower fender slightly at as you turned.
Now with a 2" leveling kit theres no rubbing.
I think you can go up to a 305 (about 12" wide) without rubbing.
Factory backspacing is 6" and a 5.5" offset will do work. Factory wheels are 7.5" wide and most aftermarket are 8.5"
I think I just kinda glanced around that but if you have any other specific questions just ask.
2500, 3/4 ton, lift, tire, tires
